I just thought you should be aware of this as I still find when I am viewing 60i material shot on the H1 I am blown away at how crystal clear it is. It looks like looking through a window! Good Luck. On a side note I recently did a 10 minute short film for a local church that is a parody of Extreme Makeover Home Edition. Despite knowing that 60i was the best choice to emulate the actual reality TV show, I still shot it in 24P because I am a sucker for the look and feel of film. Nobody noticed or said anything because overall it looked more historical and less "live" to me than the real program does. They loved it. Good Luck again! |
Couple of suggestions as well... Minus green / Magenta gels have been used for backlight to reduce spill in the past. It really depends on what you're using to key your scene as to whether or not you want to do this. Shake, dvMatte and even After Effects can use the information in the green spill in a few different ways, most popular is light wrap. The warm tint you can get using minus green on edge light can pose problems in this case as the keying software is looking for the same color as the background. If you're keying in an NLE keyer, the minus green can help. If you're not sure how it's going to be keyed, I'd not use the minus green. Another suggestion is 1/2 stop hotter on your foreground (talent) over your background. If you're doing interactive / custom lighting to your background (dimly lit bar / room) and you need your subject to match, 1/2 stop hotter may not work. The big trick is to get your screen lit evenly (65 - 70 ire) and then light your subject separately. If the screen is lit evenly, you can underlight your subject and still have a clean key. |
| All times are GMT -6. The time now is 10:49 PM. |
