-   Canon XL H Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xl-h-series-hdv-camcorders/)
-   -   What's the GENLOCK for? (https://www.dvinfo.net/forum/canon-xl-h-series-hdv-camcorders/51841-whats-genlock.html)
Edwin Hernandez September 27th, 2005 01:13 PM
Excuse my ignorance.
Since the genlock figure was almost extinct in the firewire DV world, I just don't have a clue on what do I need the genlock for. Anyone please?
A. J. deLange September 27th, 2005 01:24 PM
Genlock is used to synchronize multiple cameras with each other and with audio equipment. If one is going to switch suddenly between cameras or dissolve between them in real time i.e. with a switcher as opposed to in post it is necessary that the frame rate, line rate and color burst be running at the same rate and be in the same phase - at least that's the way it is with analogue video. With digital it is necessary that the sampling rates be synchronous i.e. that the first sample in a frame within the signal from the first camera be aligned with the first sample in a frame from the second camera. That takes care of everything as there is no color subcarrier in digital.
If audio sampling rate in a separate device (DAT recorder for example) is genlocked to the video then sound and picture will stay in alignment no matter how long the take.
Another aspect of this is when a remote camera is connected to a studio or network. If that remote camera is in the middle of a frame when the newtwork is at the beginning of one there would be a huge hiccup if that camera were put on line. Thus remote cameras are tied to studio sync, via genlock, and the studio sync derived from the network sync.
Chris Hurd September 27th, 2005 01:27 PM
Basically speaking, genlock on all video devices used on a shoot (cameras, title generators, VTR's etc.) provides a locking signal which keeps all of the devices in phase with each other... all cameras begin their field scanning at the exact same moment, enabling seamless switching at the video mixing console. If you've ever seen a "rolling black bar" on a television or video program, that's caused by unlocked, out-of-phase signals mixing with each other, thanks to an out-of-tune or altogether absent genlock. If I recall correctly the rolling black bar is the vertical blanking interval sweeping through the picture for thirty or sixty frames or so, which you're not supposed to be able to see normally.
(Edit: Aack, I posted right on top of A.J. there. D'oh!)
Edwin Hernandez September 27th, 2005 01:32 PM
Thanks.
I remember that in the old days of SVHS editing, we used to have a genlock for using with the titler.
Nowadays, will it only be used for live recording, live broadcasting or close circuits? Nothing to do with post anymore?
-EDWIN
Jean-Philippe Archibald September 27th, 2005 01:36 PM
A.J. and Chris must be using GENLOCK to be so in-phase, synchronized in their answers with each other...
Yi Fong Yu September 29th, 2005 12:51 PM
geek humor =).
so in another words, if you're have no need to synchronize anything, you don't need genlock @all =).
A. J. deLange September 29th, 2005 06:12 PM
That's right!
Steven Blye September 30th, 2005 04:28 AM
3D is a Very Good Reason to Desire Genlock
I just wanted to point out that many (judging by my encounters) have been waiting for the ability to produce 3D (stereoscopic) works. To do this one must have two cameras whose screens write in sync, but this has been impossible with the 3 chip dv camcorders that have been produced up till now. I am thrilled that finally a camcorder of this quality is now within my reach. Unfortunately I need two, but I can always rent one if that is impossible, having one to become familiar with. It has been a long wait entailing many work arounds, but I've now seen a true barrier to my work fall. So, there are some independent filmmakers who have now been included in the revolution.
You may have noticed that several big name directors are intrigued by 3D (James Cameron, George Lucas and Robert Rodriguez) and there is a renewed push in the industry to outfit threatres for 3D to help spur the digital revolution in film and lure people back into theatres. I hope soon that 3D will become part of the digital film festivals and independent 3D films will find an outlet.
Walter Graff September 30th, 2005 09:41 PM
Don't forget that without genlock you can't properly sync Time code between two cameras either.
Steven Blye October 2nd, 2005 09:38 AM
Could someone illuminate how one accomplishes Genlocking of the cameras when not in a studio setting? They both have Genlock in I believe. If there a device the slaves both cameras in the field?
A. J. deLange October 2nd, 2005 11:50 AM
The camera apparently has Genlock In only. Genlock out would be the composite video output of the master camera. This would be connected to the Genlock In port of a slave (or slaves). Multiple cameras can be daisy chained but the one at the end of the chain will be beind the master by the total length of the cabling (about 2 nS per foot). Alternatively one can buy time base generators with extra stable crystals which can serve as the genlock source for one or more cameras in the field (battery operated). If the cameras are all connected to this device with cables of the same length they will be very nearly exactly in sync.
Nick Hiltgen October 2nd, 2005 12:01 PM
Steven, amoongst other options one way to do this in the field would be to use an item called a "clockit" box. These recieve timecode from a hero camera and then lock the time code into the boxes. Once the boxes have the timecode from the hero camera attach them to the TC IN port on the slave cameras. The boxes are about the size of a deck of cards and usually are held on by velcro.
A. J. deLange October 2nd, 2005 12:28 PM
Just so we are clear on it, time code is a separate signal unless the camera generates or is receptive to VITC (Vertical Interval Time Code) which is, as the name implies, time code whose 1's and 0's are placed in the video lines during the vertical retrace interval and which can, thus, be carried in the genlock signal. The less sophisticated form of time code is LTC (Longitudinal Time Code) which is an audio bandwidth signal (it can be recorded on an audio track). The BNC connectors on the XL H1 clearly expect LTC and generate LTC. Note that the XL2 generates LTC (but not VITC AFAIK) and this signal is available from the LANC port (but in LANC format - it must be converted to LTC format before it can be recorded on an audio channel). To genlock a set of cameras and have them all recording the same time code requires supplying both the genlock and the LTC signals - that's why there are 2 BNC's on the XL H1. There are several devices designed to generate genlock and and time code, to accept LTC and genlock and repeat LTC, to generate genlock from LTC etc.
Steven Blye October 2nd, 2005 01:11 PM
A.J. and Nick, thanks for the info.
So, a clockit box perhaps would not work with the XL H1? If I'm understanding correctly, because of the sort of time code.
From A.J.'s info - I could either genlock both cameras with one device, but the timecode wouldn't be in sync, or get another device that genlocks and locks timecode as well. Hope I am understanding you correctly.
If you would have any suggestions as to the specific devices/products you would prefer in this situation, that would great as well.
Thanks again.
Nick Hiltgen October 2nd, 2005 02:04 PM
I may be mistaken but i believe that the clockit boxes have a genlock port as well. AJ is definitely more knowledgeable on this then myself though.
Steve House October 2nd, 2005 03:26 PM
There's sync and then there's sync. Think of the frame as a printed page in a book. Sending timecode from one camera to another and/or to an audio recorder records the precise time to the frame from a common clock when each device recorded its data so they can be aligned again later. But remember that the video frames are rasters made up by scanning from one side to the other along successive lines down the page, just like we read text. Sending Genlock insures that each camera is looking at precisely the same word in the same line on each page at precisely the same time. When the master camera or the house clock says "Read line 1!" every camera in the group reads it exactly in unison. That way cuts, dissolves, etc between devices can happen seamlessly without jumps in the scan. If camera 1 is looking at line 5 at the same time camera 2 is looking at line 200 even if it's within the same frame, that frame would be jumbled when one mixes the scan from one camera with the other. Genlock makes sure when the master is scanning along line 5, ALL of the devices are scanning line 5 exactly in lockstep.
A. J. deLange October 4th, 2005 06:44 AM
Steven,
If you genlock only then the time codes will be in sync in the sense that they run at the same rate i.e. each time one camera's TC increments by a frame the other ones' do as well. The time codes won't read the same however unless they are "jammed" to a common source. With the XL2 it was possible to use the remote control to bring two cameras to the same time code (but not possible to keep them locked). If the XL H1 has the same capability then two cameras can be brought to the same time code and kept together without any equipment other than a cable and the remote control. If, OTOH, it is desired to set a particular time code then an external device must be obtained to supply it.
I don't consider myself qualified to recommend any particular pieces of equipment as I'm not in the business and there are so many options available about which I know nothing other than what is on their web sites. I do use MOTU equipment to obtain word clock from an XL2 and that seems to work out for me but may be entirely unsuitable for your purposes. An XL H1 should plug nicely into this system but then again it should be possible to genlock an XL-H1 to an XL2 with just a video cable (no time code alignment without the other stuff)
Steven Blye October 5th, 2005 12:06 AM
Thanks A.J. So, just the video out (composite?) from the XLH1 to the Genlock in on the 2nd XLH1would be enough to genlock?
However, the length of cable would affect a lag in synchronization? Therefore an outside source with cables of equal lengths would assure one of a solid sync?
Am I correct in my understanding?
A. J. deLange October 5th, 2005 06:10 AM
Yes, that's correct on both counts.
WRT cabling - the sync will be solid in either case but with, for example, 100 feet of cable there will be a delay of about 200 nS which is about .004 line. Some equipment has adjustable delays of up to a line or 2 to compensate for cabling. Whether the XL H1 does or not I don't know. It's pretty clear that for short distances this isn't a problem.
Steven Blye October 5th, 2005 07:50 PM
Thanks for the help A.J. and all.
A. J. deLange October 10th, 2005 01:41 PM
I just looked at the video demo from the Resfest and one of the first things I spotted was a genlock adjustment menu item showing a negative number. This implies that the camera can be set to trigger either before sync or after thus allowing lots of flexibility with respect to sync cabling.
Steven Blye October 10th, 2005 10:44 PM
That's very good news.
