-   Canon XL H Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xl-h-series-hdv-camcorders/)
-   -   H1 - the ultimate SD cam? (https://www.dvinfo.net/forum/canon-xl-h-series-hdv-camcorders/56503-h1-ultimate-sd-cam.html)
Pete Tomov December 20th, 2005 01:12 PM
Now correct me if i'm wrong but from 4:2:2 60i HD you can get 4:4:4 60p SD.
What more do you want in SD?
I'm just checking 'cos I'm working on a project that I need exported to SD at the end and there's gonna be a lot of cc.Lighting's not an issue.
Anthony Marotti December 20th, 2005 06:15 PM
If that were true, you could capture uncompressed and have a superior editing format.
At least two problems that I can see.
1) can you actually capture 4:4:4... I doubt it (for that matter I would love to capture SD 4:2:2!)
2) Once you get back to DV, you're back to 5:1 and 4:1:1 :-(
Pete Tomov December 20th, 2005 08:29 PM
You can't capture 4:4:4 but 1080 4:2:2 can be downconverted to 4:4:4 SD.And yes,you do get 4:1:1 when you convert to dv or dvd but 4:4:4 is much better for chroma keying and color correction before you get to the final output.
Barry Green December 20th, 2005 08:58 PM
You can't record 4:2:2 60i HD on the Canon though. Its internal HDV deck only records 4:2:0.
Pete Tomov December 20th, 2005 09:19 PM
I meant over hd sdi.
