This does not sound right. I have many 72mm filters for my Canon Lenses. In all cases the standard lens cap fits fine. Did you purchase a "Thin" or "Slim" filter that does not have any outer (front) threads, one that an additional filter can not be screwed onto? Some "Slim" filters come with an "over the filter" cap. |
About filters
All filters are not equal but how much do you need to pay to get a good one? I don't know. Maybe it is about time for someone here to do a practical filter shootout; one without filter, and a few with cheap and expensive filters.
I know from my time at Victor Hasselblad we had a discussion about their expensive filters. The technicians at the development department told me that especially for long telephoto lenses, the filter surfaces have to be very parallel because otherwise it will act as one extra front lens, detoriorating the otherwise carefully designed lens system. They had found not all filters were created equal. (The tele lens has a more flat front lens than its wide angled cousin and a non parallel filter causes a a relatively larger difference.) So please go ahead and make a test. It could be very interesting. Why spend excessive money on the filter if it doesn't make any difference? Better put the money on other stuff. But I guess this HD camera needs good parallel glass, especially when you put on any of the tele converters ... BTW, the thin filter without threads at the front is made for wide angle lenses where the protruding metal could vignette the picture. Also useful as the front filter if you need to stack several filters. I prefer an ordinary UV filter with front threads for the 20x lens. It gives a little more protection and you could put on a polarizing filter or anything else on top. I have recorded about 40 Panasonic AY-DVM63MQ successfully and have had no problems so far. I used a cleaning tape after 25 tapes just briefly for safety before an important shoot. I would take this tape over Sony even if I could get the Sony for half the price. But that is my opinion. Sure many tapes could work. It is also a question about what a lost take is worth to you. But I wouldn't put cheap tapes in my camera. I guess there is a hype about this HD and clever or not knowing salesmen/companies try to get extra here ... Of course a HD camera needs better tape than a DV camera with a quarter of the resolution they may tell you and most people take that bite. Not so, the data rate is not faster because the frames are more compressed. The HDV is compressed over a group of frames (GOP). So it is very important to not get any drop-out. Any minor dirt or bad part of the tape could ruin a dozen of frames or so. Conclusion: You need a tape with consistent quality with no dirt. A tape which could be stored without change over time. A tape with good lubrication which will not cause loose particles. And so on. Or in other words: Exactly what a premium Master (mini-DV) tape is produced for. Please correct me if I am wrong. |
Buy what you can afford. Mike |
I honestly dind't know what I was getting. The sales guy said, "Ohh.. You GOTTA get this cool HD filter." I said, "Really, why?" "Well you have a hi-def camera, right? You NEED this HD glass." I bought it - literally and figuratively. |
My XLH1 should be coming this week or early next, so i'm looking at this thread for hints/tips.
I have the option to use either Sony DVM63HDV Sony DVM60PR Panasonic DVM60FE Panasonic DVM63PQ Which model would you guys suggest? They're all relatively cheap tapes, with the top being the most expensive, and the bottom second expensive. I will be buying 50 of these tapes, that would also be used in a Sony Z1(on hire) also. Aswell as an XL2. Martin |
Hi Martin D.
I think you have to try out what you think is the best tape. I myself use this one, Panasonic AY-DVM63AMQ Mini DV Tape 63Min Master Grade, and think it works fine on my XL H1. Earlier I used a cheaper tape, I had some bad experience with, but not with this one. I dont use "cheap" tape shooting in HD, but than again, different countries - different prices, so a cheap tape in one country might not be so cheap in another country :-) Compared to other countries, Norway isn't the cheapest country to buy electronics and "stuff". One DV-mini tape with good quality is about 70 NOK, in US dollar it'll be around 8 - 9. Good luck with your new camera, I'm sure you will enjoy it a lot. |
Dear Matthew,
Formatt labels some of their filters "HD". I consider Formatt filters to be very good. If you have a Formatt filter, do not feel that you have been ripped off as you have a very high quality filter. |
I'm also using the Panasonic AMQ tapes.
| All times are GMT -6. The time now is 06:53 AM. |
