-   Canon XL1S / XL1 Watchdog (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/)
-   -   XL1s pieces (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/26330-xl1s-pieces.html)
Bill Buchanan May 21st, 2004 08:34 AM
XL1s pieces
Can you purchase an XL1s with just the items you want? For instance if I want the 16X manual lens and the BW viewfinder - do I have to purchase the "base" model with the standard lens and viewfinder and spend almost three grand more for the lens and VF. Or can I order the XL1s body with the lens and VF that I want and not have to pay for the standard items?
Dave Frank May 21st, 2004 07:54 PM
You can buy the Xl-1s "body only".
http://www.bhphotovideo.com/bnh/cont...=231684&is=REG
Then you can pick up the lens and viewfinder.
Mark A. Foley May 22nd, 2004 06:45 AM
I would also consider ZGC for a specified-configured XL1s...there're first rate and a sponsor of this forum and DV Info
http://www.zgc.com/zgc.nsf/active/1D...256AC30008194D
Bill Buchanan May 22nd, 2004 10:09 AM
Thanks so much for the info. Here's one more - in the Lightworks family, it's clear that the Equalizer is a windscreen but do the other two products, System Isoloater and Universal Mini-mount complement each other? Or are they mutually exclusive?
Thanks again
Chris Hurd May 22nd, 2004 12:26 PM
They compliment each other. Either one will do a great job of dampening motor noise from the camera, but use 'em together for best results. The system isolator is very good for handheld use since it moves the camera body further back on your shoulder.
Rob Lohman May 23rd, 2004 07:55 AM
ZGC has different packages available as Mark pointed out. So
you can buy a package with the B&W viewfinder and manual
lens for example.
Click here for their packages
If they don't have a specific configuration you want give them a
call. They should be able to make you a custom configuartion as
well!
