-   Canon XL1S / XL1 Watchdog (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/)
-   -   extremely portable HD location audio recorder?!? (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/2906-extremely-portable-hd-location-audio-recorder.html)
Chris Ferrer July 28th, 2002 08:06 AM
I just wanted to run this idea by everyone and see if they had any thoughts?!?
I have been doing a lot of research lately on a portable recording setup for very mobile/high quality recording. My findings keep coming back to the tascam da-p1 or a pro minidisc recorder.
But I just put two ideas together and think it may work. First, I know the Nomad Jukebox 3 is a totally consumer device but if you look at the specs (someone also mentioned it on the site last week) it can record uncompressed .wav at 48 KHz. and comes in either 20GB or 40GB of storage with both*USB and Firewire connectivity. BUT it has a crappy front end....
Here comes the kicker, it has optical in! If one were to take the Denecke AD-20 a/d converter/pre-amp (http://www.core-sound.com/inbox.html) and use the optical out to drive the Nomad, wouldn't you have a clean digital signal to work with? Plus Firewire and USB to get to the files! (at a very afforadable price too, the Nomad 3 and AD-20 should be under $600 for the package)
Uncompressed .wav is exactly that, uncompressed! Going from a high quailty mic pre-amp to a digital signal in a professional device (the Denecke ad-20) and use the consumer device just to "hold" the audio, it seems like it would be a contender!
any thoughts?
Chris
K. Forman July 28th, 2002 03:38 PM
It sounds totally feesable in theory, but real life often proves us wrong. I think the biggest problem might be setting the Nomad to record. I haven't used one, and know little about them in general. However, it was designed to be an MP3 player, not an audio recorder. I would be interested in the results though.
Good luck with it,
Keith
Chris Ferrer July 28th, 2002 04:56 PM
So true!
I want to be an optimist on this one as all the other solutions I have looked into cost more than double this price. The controls seem pretty straight forward on the Nomad from what I can tell, a nice sized record button on the front cover... Plus, if all fails miserably, the Nomad goes on Ebay and I get a PCM-M1 portable DAT and feed it digitally with a s/pdif to 7 pin cable from the Denecke AD-20. The AD-20 looks like a sporty little unit which I can probably find a few uses for.
But if it does work, I will have a very small, high sound quality, portable recorder. (several people have emailed me already and told me that they just feed their Nomads via 1/8" stereo plug only and it works great, I just dont trust consumer a/ds)
plus this way, I can stick it in the front pocket of my portabrace case that holds my mixer and have everything in one nice little pack.
Chris
Aaron Koolen October 13th, 2002 08:42 PM
Just been looking for recording solution and found this thread. Was wondering if you got anywhere with that solution?
Don Berube October 14th, 2002 02:40 AM
Interesting.
I think I would still much prefer the sound from my SONY TCD-D10 PRO II, largely due to it being a total all-in-one solution with Abosolute Time Code. There isn't any provision for any type of time code with the setups you mention. Also, there is no Limiter. Not going to be easy at all to constrain the dynamic range of your field recordings with that setup. At least a good DAT deck such as the TCD-D10 PRO II or the TASCAM portable have very good preamps and limiters, which is key to recording good dialogue audio.
You mention "HD" in your post, I am assuming that you are referring to the fact that the .wav files are "uncompressed" and high-quality. I would suggest that if you were to compare dialogue recorded with that setup to a tried-and-true NAGRA IV STC, the NAGRA would sound much better - no high end aliasing noise or pumping, minimal or no clipping distortion, much warmer sounding due to the superior NAGRA mic preamps, minimal fuss in resolving to 24fps due to the SMPTE TC, and very easy to adjust and "ride" volume gain controls with high/ low pass EQ filtering.
I would also again suggest that the dialogue recorded from that setup would not sound as good as dialogue recorded with the SONY TCD-D10 PRO II or the TASCAM portable, since they each have much better preamps and limiters and high pass filter on the SONY.
Just a thought anyways,,, I'm sure that setup would be quite useful for certain things, but I bet you there would be some type of high end aliasing noise in the sample due to the lost cost of the components.
Chris Ferrer October 14th, 2002 05:33 AM
Don, the reason I posted this thread was in response to several of us looking for a cheaper 'all digital' hard drive audio recorder that could be easily carried while shooting. I know the sound quality may not rival a Nagra recorder but you are also looking at a fraction the cost and a much more portable unit. As for the preamps, the Denecke AD-20 has professional grade preamps but unfortunatley, no limiters...
Aaron, I ended up going with a Sound Devices MixPre (which sounds absolutely amazing!) and using the tape out jack to feed a Sony portable N707 minidisc recorder. I purchased the minidisc recorder under the condition that if it didnt work for me, the salesman said I could return it no questions asked. I brought it home, hooked it up to my MixPre and started recording, it knocked my socks off. The sound that little thing reproduced was great! minidisc has come along way, I still have my older units that dont come close to this new N707 I purchased. Im sure it helped having great preamps feeding it as well from the MixPre too.
I was never a MD advocate until now, that little recorder is velcroed to my porta brace bag and it was a very cheap investment as well. As for the main outputs of the MixPre, I feed my XL1s with those, a member here on the board made me up a custom set of padded cables that sound amazing. I am sold on the MixPre though, you have so much more control over your audio and the headphone amp also sounds 100% better too.
In the near future, I may look at swapping out the MD recorder for something along the hard drive line but for now, I couldnt be happier.
Chris
Matt Stahley October 14th, 2002 12:33 PM
there are several companies that make housings for consumer minidisc recorders which allow you the use of pahntom power and xlr etc. some even have a built in speaker if needed.
heres a link.
http://www.minidisc.org/part_Professional_Housings.html
dont know any exact details of these products but they do look interesting.
matt
Aaron Koolen October 14th, 2002 01:03 PM
Thanks for that Chris. Couple of questions. Does that MixPre have one output? If so, that obviously means that you hvae to mix your audio and then you're stuck with that mix right? Do you find this a problem?
I had read a while back that minidisc recorders were dodgy because of the compression, and that the sound from them was not suitable for dramatic movie making. You seem happy with yours, do you have anything to comment on regarding dialogue recording?
Cheers
I'm starting to look at getting a basic sound kit together for my short movies, and I think I was unrealistic in the amount of $$ id' have to spend. I'm going to have to reevaluate or go secondhand ;)
Matt Stahley October 14th, 2002 03:22 PM
MD does utilize compression - ATRAC i believe but over all i think it sounds pretty good. just like with any digital recording device u dont want to overload your signal or you'll get crap in the end product unlike the nice tape saturation you can get from hittin tape levels hard on a nice roll of analog AMPEX 2".this was a popular method of getting t hose fat huge drum sounds from the 60s & 70s not to mention all the tube compressors and limiters.
i say if you are planning for a major theatre released film then yeah you want the best audio as possible. but if you are producing video such as weddings or whatever do you really think that the person watching would be like " it sounds like they recorded this dialog on MD" i highly doubt it.
basically what im saying is that the general public could not tell the difference between a WELL RECORDED dialog take on MD/DAT/CD unless they all have "GOLDEN EARS" which is very unlikely.
ive recorded a lot with a sony consumer MD and an AT 822 stereo mic plugged directly in and got decent sound. to me its all about mic placement and setting your record levels correctly.
Chris Ferrer October 14th, 2002 04:40 PM
Aaron, the MixPre has 2 main XLR outputs (L+R) and a tape ouput. Each channel has a Left-Center-Right selector so you can actively mix both channel inputs. I run the tape output into my MD recorder and the main XLRs out to the camera. So the MD basically acts as a backup recorder. Using the MixPre allows me to control the audio I capture on my camera a lot better than just using a beachtek or ma-100/200. (and it sounds fantastic!)
Matthew is 100% right, I think it takes "golden ears" to differentiate between a good clean CD/MD/DAT recording. The key, Record it right the first time. Now most my work is event videography and dialog, anything else may be different...
I was totally hesitant about all the "compression" arguments as well, I wasnt even going to go the MD route becasue of it... but walking through my local Circuit City one day I picked up the N707 and started wondering... plus the price was right! as I said, I tried it and was very happy with what I came up with. Plus I saved alot of money too.
Again, I belive it has a lot to do with the high quality preamps and circuitry of the MixPre too. They make a good combo.
Chris
Scott Silverman October 14th, 2002 09:04 PM
Chris,
How do you get the audio off the MD recorder into your computer? Do you do it so the signal stays digital or so the signal is converted to analog? I was thinking of going the MD route also but wanted to keep my sound 100% digital. You help is greatly appreciated.
Robert Knecht Schmidt October 14th, 2002 09:21 PM
I don't know if it qualifies as "extremely" portable, but the Deva audio recorder is a 4-channel HD recorder that is constantly recording input audio to buffer and backs up selected queues to DVD-RAM when idle. It's an excellent professional location-audio-for-film-production recording solution.
Scott Silverman October 14th, 2002 09:28 PM
I think he was looking for somthing a little less than $10000. Just a thought. That thing looks like it would work pretty damn well though. Did you say it was for film? As in like hollywood uses it?
Thanks.
Chris Ferrer October 15th, 2002 05:27 AM
Yes, the DEVA is absolutely amazing! but so is the price tag that comes along with it... As much as I would love to have one, it may be a bit over-kill for doing weddings and documentaries. I believe it is gaining popularity among Hollywood film crews as we speak, several other companies seem to be following their lead as well, I know HHB is designing a portable multi channel HD solution as well. All ya need it $$$$$
Scott, as for retreiving the audio off the MD recorder, I was rather upset to find out that you cannot upload audio via the NetMDs USB interface yet (I think they are working on that with Sony), you can only download audio to the unit... So I used the included optical cable and did a straight digital copy to my external Tascam CD burner (it has optical in). Then I toss the CD into my mac and FCP gobbles it up. If you have a decent audio card, chances are it has a S/PDIF input, all you need is a little converter to change the optical signal into a S/PDIF signal and you have a lossless digital connection to capture from.
Chris
Robert Knecht Schmidt October 15th, 2002 01:30 PM
Jai Guru Deva, Ommmm
Well, I didn't say BUY the Deva. But if you're working on any kind of project that would have budgeted for a Nagra rental along with the rest of the location audio kit, go with a Deva instead. It's higher dynamic range, offers better options for monitoring levels, and a principle advantage of working with a Deva is that it can accept a synch signal from a camera and permit for really easy (i.e., automatic) audio track lineup in ProTools, etc.
Matt Stahley October 15th, 2002 02:47 PM
chris
i do the exact same thing with any audio i record either MD or on my digital 8 track.burn it to my Tascam stand alone CD recorder(i recommend these to anyone looking for stand alone cd recorder they are built like tanks!) and drop into FCP.i had the recording equipment before my G4 so never really had the need for sound card with SPDIF using this method.
matt
Scott Silverman October 15th, 2002 04:42 PM
Chris or Matt,
Does the Sony N707 have an optical out? I looked on Sony's site and their specs for the N707 are as follows:
-Inputs: DC In 3V, USB (mini-B), Optical Line In (stereo mini jack), Mic In (plug-in power, stereo-mini)
-Outputs: Headphones/Remote (stereo mini)
The site said nothing about and optical out on the player. If the optical in serves as an out port also that would be great and solve my all-digital problems. I could then use an SPDIF card to transfer through the optical out on my player and into my computer for editing. The reason I was hesitating on buying a MD was because I never thought they had an optical out. So, do they? Thanks so much!
Matt Stahley October 15th, 2002 08:11 PM
scott
sorry to mislead you mith my info. i own the sony RZ-55 MD its a couple years old it only has optical in.im not sure of the newer models.Knowing sony they dont since they play a big role in this music piracy thing. i do know that the prosumer/pro sony,tascam MD recorders have digi ins&outs . i have to use the analog inputs of the tascam cd-recorder when recording audio from the MD line out.the AD/DA converters are excellent in the tascam and it also has a passthru feature for them.
i also use a roland vs880 digital multitrack. now this has both coax/optical outs so i use these usually coax for mixdown of voicovers etc. to cd directly into cd-recorder.the roland has built in mastering kit to get optimum levels to cd if needed.this too can be used for AD/DA also with all the fx and mixing capabilties recording straight to cd or to both the multitrack with a mix going out directly to cd .
Doug Quance October 17th, 2002 11:43 PM
For What It's Worth...
I, too, want to capture great digital audio without costing a fortune.
I just picked up a Mackie 1202VLZ Pro mixer ($350) and a ZOOM multitrack digital studio with cd burner ($850).
Did some research and found a veteran audio engineer that is now building a new line of microphones...(THE brand) but they were a little too pricey for me. Lucky for me, he has collaborated with an old established Russian microphone manufacturer under the name Oktava. He brings the mics into the U.S. and checks them out and matches them. These mics are very impressive when bought in matched stereo pairs! Two sets of preamps, two omni's, two cardioids, two hypercardioids and two large diaphragm LOMO heads... with the micro cables... and the shockmounts and pop filters ($2000).
Also picked up two EV lavs (slightly used, $150 on eBay), two AKG shotguns (slightly used, $400 on eBay), and six microphone stands ($140).
Top it off with a JoeMeek stereo compressor for colored compression ($200.00) and an RNC-1773 Really Nice Compressor (stereo) for transparent compression ($200)
So, I am into this for a little over $4K. It's abilities are priceless. Hell, if you're going to cough up $5K for a camera and a few accessories... $5K for a decent NLE... what's a few bucks for audio?
I don't have much experience with video, but I've had some audio experience. What this setup can do would have cost over $100,000 back in 1985.
I figure that audio is every bit... if not more... important than the video, itself. Capturing and preserving good sound, to me, is paramount. What is often forgotten... is the capture. Good microphones are VERY expensive. I know an engineer that has three tube mics that are worth more than $10K each. Yes, EACH.
If you have a good microphone, you have a decent chance of getting good sound. If you don't... the odds quickly change.
This setup can allow me to route the mics into the mixer, shape the sound, and send one stereo signal to the camera... and another to the hard disc recorder. I have full control over the audio, with a backup. My next acquisition will be a set of Sennheiser Evolution wireless systems.
I know this is overkill for most video projects, but my intent is to do audio-only production with it, as well.
Now all I have to do is learn the menu on that ZOOM recorder... grrrr...
