Premiere Pro 2 Presets
Just downloaded and installed the Prospect2K trial for use with PP2 and AE7. I have a couple of issues with PP2 which I'm guessing are to do with the installation process.
1. The Prospect presets do not show up in Premiere and I cannot find them anywhere on my PC. (assuming they have the .preset extension) 2. Footage will import into bin but will not display correctly in timeline or preview, just flashing green frames AE7 works perfectly, imports footage very nice indeed :-) I'm assuming there has been an installation problem but not sure how to resolve it. |
If you don't have the presets you are likely missing all the plug-ins as well. Contact support and the up you fix your install issue, which is normally due to Adobe's plugins registry being missing or corrupt.
Wow that was fast!!! Thanks for the help David, I'll get in touch with them
Isn't it Sunday in the US at the moment, go home man :-) cheers Dean |
Just a warning, Monday is a holiday here in the US, so support won't be back until Tuesday US PST. Yes, I had better get back to my weekend.
Problem solved, great support from Cineform.
maybe you can share the solution here and help other people having the same problem.
If you're having this problem, just contact support and tell us which version of Premiere you're using. Then we'll send you the appropriate patch. |
Which reminds me.....before you add the patch to the registry open it in a text editor and make sure the path is correct. The file I got from Cineform had a default of "C" drive, my apps are in "E".
I use PPro2 so what worked for me won't if you're using CS3. Thanks again for the great support guys. Quote:
| All times are GMT -6. The time now is 11:30 PM. |
