Cant render Quicktimes in Prospect 2K
I Cant render to Quicktimes in cineform codec in After Effects, a error appears saying that i dont have the codec installed, I ran the after effects registry tool but nothing happens. This problem happens with the latest two build of Prospect2k software and AE CS3. Same problem in both workstations.
There is no option for trillions of colors either. |
Weird. Only 3.1.1 supported QT within AE CS3 anyway, make sure you have that. The "Fix After Effects" tool should add this data below to "Adobe After Effects 8.0 Prefs.txt"
["QuickTime 64-bit Input Codecs"] "CFHD" = "1" "DV10" = "1" "Mczm" = "1" "NO16" = "1" ["QuickTime 64-bit Output Codecs"] "CFHD" = "1" "DV10" = "1" "Mczm" = "1" "NO16" = "1" Make sure you "Fix After Effects" is finding the Prefs file. If it is missing you Prefs file open it up and add the missing "CFHD" = "1" lines. If that doesn't work, try support. |
Im running the latest Prospect Build, the same happens in two different workstations, same configuration, different memory siza and OS.
I will try support |
| All times are GMT -6. The time now is 08:44 PM. |
