-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   New Aspect/Prosect HD/2K version in beta open beta (https://www.dvinfo.net/forum/cineform-software-showcase/107401-new-aspect-prosect-hd-2k-version-beta-open-beta.html)
David Newman November 6th, 2007 11:11 PM
Welcome to version 3.2 (PHD/P2K) and v5.2 (AHD.) There have been I lot of under-the-hood changes and some new features and several bug fixes. As so many elements have changed in the release, I though I should beta test with DVInfo users first -- you are a calmer, more thoughtful lot. :)
Another reason to release as beta, is HD Expo is on for the next couple of days, halving our support staff at the office. So anything you find wrong with the beta post here or send a measage my DVInfo account -- I'm not going to HD Expo (sadly it is a show I always miss, yet I've heard good things http://www.hdexpo.net/.) If all goes well we hope that 3.2 can be out officially sometime next week.
Big additions :
1) NVidia level shifts, we stopping trying to use their broken YUV surface, now you can preview to RGB surface, preventing the color shift. In the playback controls you can now set whether to use YUV surface or not.
2) M2T export is back, and much better than before, as it now uses the Tsunami MPEG2 Encoder directly through the CineForm M2T export movie option. As it has been a long time since this worked correctly, here is a technote to remind everyone how to use the M2T export : http://www.cineform.com/products/Tec.../M2TExport.htm
Links:
Prospect HD : http://www.miscdata.com/cineform/Pro....141-Setup.zip
Prospect 2K : http://www.miscdata.com/cineform/Pro....141-Setup.zip
Aspect HD : http://www.miscdata.com/cineform/Asp...0.94-Setup.zip
Carl Middleton November 6th, 2007 11:17 PM
David,
I may be a complete dunce, but where can I download the beta? :)
Carl
David Newman November 6th, 2007 11:47 PM
Links are now up in post (sorry!)
Carl Middleton November 6th, 2007 11:53 PM
Looking foward to this one!
Also, finally got around to testing 50i (no cineframe, Z1) -> force progressive, slow 4%.
Looks phenomenal! I don't think I'll be filming in 60i anymore. :)
Working towards an endgame plan with all this, I really am, more news to come if it comes to fruition and becomes something worthy of tossing in your press kit. I can think of some nice blurbs about how Cineform has been instrumental in pushing my workflow to the next level. :)
Carl
Carlos Bustamante November 7th, 2007 05:41 AM
The clips captured with Apect 5.2 (beta) converted to avi look good and play well with classic media player and in after effects but collapse into horizontal stripes in PPro CS3. Still images in Premiere look great and exporting to Canon xh-a1 works fine. I reinstalled Aspect 5.1 build 92 and the clips captured with Apect 5.2 (beta) now worked the way they should in PPro CS3.
Thanks for all your improvements and expertise!
Carlos Bustamante
Craig Irving November 7th, 2007 08:25 AM
What are the proper steps for exporting a 24p timeline back to a Sony V1U in 60i? Is it as simple as setting up the export settings as 29.97fps or is there a specific pulldown technique I need to be adding?
Can't wait to try out the new beta when I get home.
Thanks David!
David Newman November 7th, 2007 10:25 AM
Carlos, Thanks for your report, testing was mainly down in Prospect, not supprizing to hear of an Aspect glitch in the beta. We will look into it.
Craig, 1080p24 exports are automatic from a 24p timeline. The CineForm M2T export will ingest the necessary pulldown for 24p to be exported back to HDV. No place 24p on a 60i timeline as Premiere tends to frame blend rather than adding pulldown (looks bad.)
Carl Middleton November 7th, 2007 10:55 AM
David,
When I try to uncheck Force YUV in the Playback Settings, and hit ok, it reverts back to checked.
When I play back, I still get the color shift, and when I go into playback settings again I find the check mark back. I tried accessing it from Project Settings as well as through the preview monitor pulldown menu, same results.
I also tried a couple of random renders in HDLink, worked fine. I'll be testing more randomness later, any hints as to what you feel might need to be put through the paces in the new version?
Also, with this new version, can I test export to m2t, or will it use the 1.5 render engine like it has been? I don't really want to uninstall 1.5 to test it out, but I would like to test it for ya. :)
Carl
David Newman November 7th, 2007 11:58 AM
We reporting issues, please include whioch of the 3 three products your are using.
As for CineForm M2T export, all Premiere versions run CineForm will now use the Tsumani encoder.
Stephen Armour November 7th, 2007 12:15 PM
David, were you able to include any new changes to this new Prospect beta that could affect the problem with PP3 and the RAM memory running out of headroom? I'd download it this sec if that's a possibility...
David Newman November 7th, 2007 12:22 PM
Adobe memory shortage issue have already been addressed about as much as we can. CineForm pretty much supports larger HD projects than any other vendor, now it is up to Adobe.
David Newman November 7th, 2007 12:24 PM
Carlos,
Your issue doesn't happen here. Try a re-install as your PC is behaving like it doesn't have an importer for Premiere.
For CS3 users the importer (im-CFHD_File_Import.prm) is installed :
C:\Program Files\Adobe\Common\Plug-ins\CS3\MediaCore
and
C:\Program Files\Adobe\Adobe Premiere Pro CS3\Plug-ins\en_US\CineForm
Check those locations.
Stephen Armour November 7th, 2007 12:25 PM
One more thing: is that Tsunami encoder the same one included in TMPGEnc 4.0 XPress ?
David Newman November 7th, 2007 12:32 PM
Confirmed : Force YUV in the Playback Settings isn't sticking in Aspect HD, in Prospect this work fine. The fix is complete in house.
Stephen Armour November 7th, 2007 12:32 PM
Originally Posted by David Newman (Post 771724)
Adobe memory shortage issue have already been addressed about as much as we can. CineForm pretty muchs support larger HD projects than any other vendor, now it is up to Adobe.
Ok, I guess we might as well just figure that until 64bit Adobe versions come out, we're up the creek.
We have to dynamic-link a lot of stuff to AE just to see it and get it to render correctly, and that makes previewing in PP3 a joke! We broke up everything into little bitty sub-projects and still have probs with multi layers of 1920 video or mixing large images and video. At this rate, we'll end up just using AE !
David Newman November 7th, 2007 12:35 PM
Very likely, it might even be a slightly newer revision. XPress will give you more controls, yet the library we licensed integrates the HDV encoding features into Premiere for straight forward M2T exports.
Stephen Armour November 7th, 2007 07:06 PM
David, do we load this beta as usual (uninstall Prospect first, then install beta) and can we load this beta without blowing our registered versions out the door?
Tnx
Jon Jaschob November 7th, 2007 07:16 PM
A Ok
Stephen >>>>Install is the same, no SN, Activation problems...
Tested m2t export, Aspect 5.2 PPro2. Worked without a problem. Wish the file extension was automatic, I always forget to write it in....
When do you think you will be releasing the overlay fix? Just knowing it's out there makes me want it all the more :-)
Jon
nVidia user :-(
David Newman November 7th, 2007 07:20 PM
Tnx
Uninstall old, reinstall new, is always prefered, registration is no affected. Never de-activate, unless you are moved your license to a new PC.
David Newman November 7th, 2007 07:21 PM
I don't know what this means.
An Aspect HD build with the Force YUV fixed should be up in a day or two.
Carl Middleton November 7th, 2007 07:36 PM
YUV/Overlay Issue
I'm having a problem which might be related to this beta (Aspect). With playback on timeline/source monitor/etc, video appears via the overlay surface while scrubbing. During playback, the video disappears from the external monitor's overlay (actually the whole overlay disappears, leaves my background color) but plays fine on my main screen. It reappears as a still on the external monitor when playback stops.
I opened an old project with force YUV enabled, played back fine. Created a new project in 60i (problem first noted on 24p project) and ran into the same problem. Might it be that I need force YUV enabled for some reason? Running a geforce 8800. Can't toggle the YUV as noted above or I would narrow it down for you. :D
Thanks for the changes, at least I can properly color correct my LCD in the meantime. :)
Carl
David Newman November 7th, 2007 08:01 PM
Some graphics card will only output the exterbal overlay in YUV not RGB. If your 8800 does that, put that is the bucket of more of NVidia mistakes.
Peter Ferling November 7th, 2007 08:07 PM
I don't think any of the 8000 series gamer cards will support dual hardware overlay, you'll need a Quadro FX for that feature, (I believe the ATI HD2000 series will support dual hardware overaly).
Carl Middleton November 7th, 2007 08:27 PM
Argh, good to know. I was hoping that nvidia craziness was over.
On another note, I get a serious error has occurred, premiere has to shut down on m2t export now with the beta, as soon as I hit render. :( Hate to be the bearer of bad news! Is it possible I need to remove the 1.5 HDV directory from 2.0, or uninstall 1.5?
On a happier note, it seems that capturing and converting to cineform as a 1 step process is more stable now on my end. I went ahead and gave it a shot for the first time in awhile, and it worked fine on a capture length that had been giving me problems before. Was there another tweak in there? :)
Carl
David Newman November 7th, 2007 10:14 PM
Steps to reproduce please.
Carl Middleton November 7th, 2007 10:43 PM
David,
I had rolled back to previous stable version to get some work done, upon a fresh reinstall the problem seems to have resolved itself. I tried it using the exact settings (24p m2t export, max quality other than that default settings) and it worked like a charm!
Probably chalk this one up to an XP driver glitch on my end or somesuch. Sorry!
Carl
Stephen Armour November 8th, 2007 02:24 PM
Is there any beta for NEO 2K as well?
David Newman November 8th, 2007 02:51 PM
No. Only Premiere based tools for now. Prospect 2K can be used to test NEO 2K features anyway.
