Double Checking: Neo Scene has 24p pulldown? at DVinfo.net
CineForm Software Showcase
Old January 5th, 2009, 01:36 AM   #1
Just double checking because I'm having trouble finding this information on your Web site.
If all I really need is something that will take the 24p-in-60i files recorded in the Canon HG10 & 20 series cameras, and convert them into true 24p files which can be edited in Sony Vegas, I want Neo Scene, correct?
Equip: Panny GH1, Canon HG20, Juicedlink, AT897, Sennh. EW/GW100, Zoom H2, Vegas 8.1
Brian Boyko is offline   Reply With Quote
Old January 5th, 2009, 10:02 AM   #2
Yes - Neo Scene includes 24p extraction. I'll add a little more clarity on the product page.
David Taylor is offline   Reply With Quote
Old January 5th, 2009, 03:08 PM   #3
Awesome! Thanks.
Only other question - and probably one I can get answered via e-mail - if I buy a copy for myself at home, do I need to buy a second copy for myself at work? Is it per site or per user?
Another thing: I've been archiving my files as H.264 .mov files (a few are mpeg-2). Can I use Neo Scene to quickly create mastering files?
Also, can Neo Scene convert only -part- of a file to Cineform, for intermediate codec editing? Say 5 minutes out of a long AVCHD interview?
Old January 5th, 2009, 03:53 PM   #4
CTO, CineForm Inc.
The licensing is officially one user one machine, but we understand that users have laptops or home PC so we are flexible and allow for two activations. This is not for two users on two PCs, but for single user flexiblity.
"Also, can Neo Scene convert only -part- of a file to Cineform, for intermediate codec editing? Say 5 minutes out of a long AVCHD interview?"
You can stop a converion part way through, and the resulting AVI is valid, but otherwise we convert entire clips.
Old January 5th, 2009, 03:55 PM   #5
Brian, following is a post today about licensing for Neo Scene that I answered. Rather than duplicate I'll point you to it: http://www.dvinfo.net/conf/989365-post34.html
Regarding archives - yes absolutely. Neo Scene is designed for converting HDV and AVCHD files, so if the sources you want to convert fall within those guidelines then it will be perfect. If you have a broader assortement of AVI or MOV files then Neo HD might be required as it will convert many more file types.
Neo Scene does not do partial conversions. But after conversion you can use Virtual Dub (free utility) to trim clips without the need to render.
Old January 5th, 2009, 05:42 PM   #6
What is needed to convert 5D Mark II video files?
Bill Binder is offline   Reply With Quote
Old January 5th, 2009, 05:58 PM   #7
Bill, there are a couple threads here about converting 5D2 footage using CineForm - they're easy to find. You'll need either Neo HD or Prospect HD. "Today" you need to install some extra components as indicated by the existing threads. "Today" is in quotes because in the next 2-3 weeks we'll eliminate the extra components and will support 5D2 conversions directly in Neo HD/Prospect HD.
Old January 5th, 2009, 11:00 PM   #8
Thanks, I was kind of hoping Scene would be enough. Oh well, the price is just a little too rich for an amateur who's just making web videos (which is my case). I'd consider buying Scene if it could handle the 5D2 files. I just want to be able to edit 720p intermediates of my 5D2 files in a Vegas timeline for final renders to 640x360 Flash. I've actually got a decent workflow already for batching clips using the built-in Cineform in Vegas (rough edit > events to regions script > batch render to 720p intermediate), but I'm trying to find a solution for the crushed blacks problem in my workflow, so thanks to the QT decoder and the way Vegas works I guess, I'm looking for an easy solution outside of Vegas...
Old January 6th, 2009, 12:14 PM   #9
Yee Haw.
I fixed the problem.
Here's what I did: I downloaded the trial version of NeoHD, and this wouldn't convert the file either, but it gave me a much better reason: I didn't have an AVCHD codec installed.
Downloading CoreAVC and installing it allowed NeoHD to convert the file to Cineform.
I then uninstalled NeoHD trial and then reinstalled NeoScene.
It's converting now. No errors.
If I had to guess, I think it's just that I didn't have CoreAVC installed, and the cryptic error message didn't help me figure out that was the problem.
:D
Old January 6th, 2009, 12:57 PM   #10
CTO, CineForm Inc.
Brian,
I missed something, which file wouldn't convert, yet adding CoreAVC it would?
Old January 6th, 2009, 07:43 PM   #11
Originally Posted by David Newman View Post
Brian,
Damn, now I've got an audiosync issue. I think it may have something to do with this tape, which I know has a dropped frame somewhere in it.
I'm going to capture to M2T and see if the Audiosync problem is there. Then I'll try Vegas. If nothing else, I can always resync the audio manually.
Old January 6th, 2009, 10:07 PM   #12
Okay, capturing to M2T and then converting to Cineform to remove pulldown works.
NOW I've got another problem. Importing the converted Cineform files into Sony Vegas, I'm getting a flickering problem. It's fine when I play the cineform file, but once I bring it into sony vegas, it looks like this.
http://www.blogphilo.com/rawfootage/...ffe%20test.mp4
Every 8th frame, for 2 frames, I'm getting that weird color shift.
{EDIT}
Nevermind. Fixed it. Just a fluke, a re-transcode cleared that right up.
Old January 7th, 2009, 09:52 AM   #13
I'm getting that too (The flickering). How did you 'fix it'?
Simon Dean is offline   Reply With Quote
Old January 7th, 2009, 10:26 AM   #14
I wish I could tell you how, all I know was that I deleted the flickering file, then redid the pulldown (from the M2T file) in NeoScene. This time the flickering was gone.
There was one problem - Rendering to Cineform FROM Vegas, I wasn't able to get audio working. A frustration.
Old January 7th, 2009, 12:20 PM   #15
CTO, CineForm Inc.
Never seen that. I would love to send a short CineForm AVI that does it. If your samples are too long, use VirtualDub to chop the clip using Direct Stream mode. Also use VirtualDub to confirm the error. The clip look like it is switching colorspace, very weird, maybe Vegas only (as it requests the color space from us.)
