-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Prospect HD 4.0.1 crashes PPro CS3 (https://www.dvinfo.net/forum/cineform-software-showcase/235525-prospect-hd-4-0-1-crashes-ppro-cs3.html)
Mario Jesmanowicz May 17th, 2009 05:29 PM
I just downloaded and installed latest version of Prospect HD 4.0.1 and it looks like that fixed my pulsing problems on conversion from canon hg20 with HDLink (batch files) but now when I import any cineform avi files the PProc CS3 crashes with an error:
"Sorry, a serious error has occured that requires Adobe Premiere Pro to shut down. We will attempt to save your current project"
if I import music, photos or any videos (that are not cineform avi's like wmv, mpg, quicktime etc...) everything works.
Also if I start new project with some PPro cs3 templates like DV or HDV and try to import cineform AVI, it also crashes.
So the common thing is importing any Cinefrom files wether converted with new HDLink or previous version of HDLink, the PPro crashes.
Anyone had these issues?
thanks for any help
David Newman May 17th, 2009 05:39 PM
This has been explained, some PCs are getting CS4 importer components in the CS3 folders (our installer bug -- we don't know why yet), and Adobe doesn't think to check for this (they changed the API, and never thought to put a version numer in it -- Adobe's bug.) So look for CFHD_AVI*.prm and CFHD_MOV*.prm inside your program files/Adobe CS3 folders. Delete any that you find.
Mario Jesmanowicz May 17th, 2009 07:06 PM
that looks like it fixed the PP CS3 crashing
Param Sivan May 18th, 2009 03:53 PM
First light doesn't load
Hi David,
I loaded CFH 4 and had so many problem..nearly ripped my computer aprt yesterday. Thanks to this form after spendig 8 hours I finaly found out that it is an Adobe error. I deleted the CFHD*prm file and thank god it works smoothly now..
Now My First light is not worknig at all even from the first time I installed CFHD 4..
please advise
Martin Rahn May 18th, 2009 05:55 PM
Originally Posted by Param Sivan (Post 1144988)
Hi David,
please advise
I am pretty much in the same position. Both CS3 and CS4 are playing nicely with PHD 4.01.
Unfortunately, First Light has never run. It always crashes with the following dreaded message:
"First Light has encountered a problem and needs to close"
Here are the details:
"Event type: CLR 20R3
P1 FirstLight.exe
P2 P2:0.0.0.0
P3 4a0db50f
P4 Presentation framework
P5 3.0.0.0
P6 45398c20
P7 6496
P8 be
P9 System.windows.markup.xam.parse
I am running Windows XP Pro 32 bit with a QX9650 quad processor and nVidia 8800 GT.
Any suggestions would be appreciated..thanks.
Marty
Jay Bloomfield May 18th, 2009 05:57 PM
Do you have .Net Framework 3.5 installed?
http://www.microsoft.com/downloads/d...displaylang=en
First Light needs it to run properly.
Martin Rahn May 18th, 2009 08:58 PM
Jay:
Thank you. I installed it and First Light works!
Marty
Param Sivan May 18th, 2009 09:13 PM
First light
Originally Posted by Martin Rahn (Post 1145142)
Jay:
Marty
Hey we should thank this guy heeps man..bloody hell I had so much problemand there is no way I would known that..
How many Presets do u have or can u see under your first lihgt preset for color match ie Kodak..
David Newman May 19th, 2009 11:36 AM
duplicate post
David Newman May 19th, 2009 11:38 AM
Mario and other that had or have CS3 crash issues with the installer, please try the test described here: http://www.dvinfo.net/conf/cineform-...0-1-210-a.html
Trying to get some test data on this particular failure.
