no audio stream found
Dear friends, I had to reinstall. CineForm NeoScene 1.3.4/119 now converts only video. The HDLink log sais "No audio stream found". When I play converted file I hear a strange wrrrr noise. AC3 filter installed, Win7 64bit, original 5D movs plays with sound. Any ideas please? Lukas
Reinstall the AC3 filter.
reinstalled AC3 still the same
Thanks. Tried to reinstall AC3 Filter, same message, same sound. Tried to google simillar problem with no success. Before disc crash I had Neo Scene on a new Win7 64 and it worked fine with no other AC3 filter. The same hardware with WinXP + AC3Filter is fine. So there must be some other issue. I just do not know what to fix. Lukas
Down GraphEdit, and see if your camera plays within that. It will should which audio component it uses. Also contact support.
| All times are GMT -6. The time now is 10:06 PM. |
