New Mac Betas at DVinfo.net
CineForm Software Showcase
Old March 30th, 2011, 04:40 PM   #1
Sponsor: CineForm
New Mac Betas
These fix a few minor bugs.
http://www.cineform.com/downloads/Ne...02b-110330.zip
Please post any issues on this thread. Thanks.
Jake Segraves is offline   Reply With Quote
Old March 30th, 2011, 07:07 PM   #2
Re: New Mac Betas
Thank you for the second monitor support! it even works better than the PC, realtime playback with sound.
Everything smooth so far.
Martin Guitar is offline   Reply With Quote
Old March 30th, 2011, 10:51 PM   #3
Re: New Mac Betas
One issue found so far is that a side-by-side 3d decode to 2vuy (QuickTime, FirstLight main screen or FCP with 4:2:2 or 4:4:4 source) does crash.
Craig Davidson is offline   Reply With Quote
Old March 31st, 2011, 05:58 PM   #4
Re: New Mac Betas
New updated version.
Fixes a problem with crash on side-by-side viewing of 422 files.
Fixes dark frames rending single eye from 422 stereo files.
Fixes the 4444 encode problems when encoding from Animation codec.
http://www.cineform.com/downloads/Ne...04b-110331.zip
Old April 1st, 2011, 07:13 AM   #5
Re: New Mac Betas
These links are broken.
John Reeve is offline   Reply With Quote
Old April 1st, 2011, 09:19 AM   #6
Re: New Mac Betas
When exporting to Cineform (Neo HD) from After Effects with this beta, the result is brighter. When converting the same clip from REmaster everything is ok. Footage is from Canon 5D. No filtering selected in Remaster and settings in AE are: 16Bit Project, trillion color with quality slider to 100.
See screenshots:
Original H.264
ImageShack® - Online Photo and Video Hosting
CF export from AE
I'm also wondering why there's no MOV exporter from AE? I know David said it was not necessary but why make different export option within the same suite of software. There's an exporter in Premiere but in After Effect the Quality slider to 100 is "Filmscan 2" and 0 is "LOW"...
The new beta links are broken.
Old April 1st, 2011, 10:06 AM   #7
Re: New Mac Betas
Exporting from AE is odd at best. We have some patches to the codec configuration file that will at least tell AE that the codec would like the material in 16-bit RGBA. AE exporter sees that and will give you the option of "Trillions+" colors. Unfortunately, it then opens the QuickTime encoder with for an 8-bit 4:2:2 encode. The Apple QuickTime interface then converts whatever AE passes into 8-bit 4:2:2 data before passing it to the encoder.
Looking into the links..
Old April 1st, 2011, 10:14 AM   #8
Re: New Mac Betas
Is this the patch you are refering to?
When i added these tags to MediaCoreQTCodecRulesCS5.xml i could select trillion +. Thanks to David N for the info.
<QTCodec codec='CFHD' vendor='****' platform='mactel' direction='encode' versionlow='0x00000' versionhigh='*' gammatag='false' cvbuffertag='0' deepdecodefourcc='b64a' decodefourcc='argb' />
<QTCodec codec='CFHD' vendor='****' platform='mactel' direction='decode' versionlow='0x00000' versionhigh='*' gammatag='false' cvbuffertag='0' deepdecodefourcc='b64a' decodefourcc='argb' />
Will there be a solution to the brightness issue when exporting from AE? It was fine on the PC before.
Old April 1st, 2011, 10:27 AM   #9
Re: New Mac Betas
Links should be working now. If you get the "Page Not Found" message, clear your browser cache.
Old April 2nd, 2011, 09:02 AM   #10
Re: New Mac Betas
I am really enjoying the external monitor support guys.
Old April 2nd, 2011, 09:35 AM   #11
Re: New Mac Betas
Thanks for all the info Craig. I don't really understand your post about the export issue within AE. It's a little much for me to grasp... Are you saying that exporting from AE is really 8bit contained in a 10bit file?
Is the issue fixable or do we have to forget about exporting Cineform from AE?
Old April 2nd, 2011, 02:25 PM   #12
Re: New Mac Betas
It is fixable. On the PC it was fixed by only presenting the 16-bit 'b64a' pixel format as supported. This is not possible on the Mac, since FCP requires '2vuy' as the first pixel format. The fix does need to come from Adobe. We had the same problem with the AJA stereo encoder, and fixed that. We also saw the same thing with RedCine, and worked with the engineers at Red to solve it as well.
Old April 2nd, 2011, 10:26 PM   #13
Re: New Mac Betas
In FirstLight the "contrast" slider and all "gamma" sliders don't work under "primaries". (gamma, red, blue and green).
All the other controls work fine.
Old April 4th, 2011, 05:29 PM   #14
Re: New Mac Betas
Today's update.
Fixed a couple of memory leaks in FirstLight stereo mux.
Double checked the contrast and gamma controls.
http://www.cineform.com/downloads/Ne...06b-110404.zip
Old April 4th, 2011, 07:03 PM   #15
Re: New Mac Betas
The "contrast" and "gamma" sliders now work but the masking issue on YUV footage is back. Weird grey bars show up again
