Audio Drop Outs?
I have just exported thru HDLinK an .m2t File created via the Export>Movie command in P/Pro. When playing back the finished project from the recorded tape, I noticed some very short audio drop outs. Suspecting that they might be tape related drop outs, I recorded another pass to the same tape, at a different location from the first... and again some audio drop outs occured, at or near the same locations on the program. I recorded two more passes with the same result. My Time Line audio sounds fine, no glitches, Etc.
Anyone have these same kinds of difficulties? Might I be missing something with the Audio Set Up within the Export Command? What do I do???? Thanks, Gary |
When you play the m2t file does it have this fault?
David,
When I listen to the camera audio during capture, I here the drop outs. When playing back the Tape in the camera after it has recorded, I also here the drop outs. I tried to load the m2t file from the drive into P/Pro and I get the indication that the "file will not play, it is damaged". I might perhaps be doing something wrong with playing the file. In the original m2t File creation, I used a 1 Frame audio Interleave as the audio compressor option. Might I try another setting, like 1 Sec. perhaps? Thanks, Gary |
Play the M2T file with VLC or another MPEG player.
OK David...
But pardon my ignorance. What is VLC? and whare might I find It? My edit system is not hooked up to the internet... I have had many problems with our connection and do not trust it with the Edit PC. Thanks, Gary |
It is a free MPEG player that works with M2T. Type VLC into google -- it is the first entry.
David,
I Downloaded the VLC software as you suggested and played the .m2t File. There were NO audio drop-outs!!! And the video looked GREAT... Does this mean that I am suffering from Tape Drop Outs, or something else? The video seemed to be clean, with no visible drop outs. I guess that I should open up a new Tape and try it again??? The previous tape that I recorded to was also new, from the same JVC ProHD batch. I pre striped it before recording. It only had that single record pass. Thanks again for your help, Gary |
Now that we have ruled out the source M2t file (which is good), I guess try again, it should be working fine.
P.S. Don't do anything else on your PC whlie exporting the M2T to the camera, just in case. |
To All and David,
Tried it again. Still the same audio drop outs. Tried different Firewire Port, New Tape, and still Audio drop outs????? What to Do... Thanks, Gary |
You will need to work with support as there is so much I don't know about your setup.
Thanks David. I will try to contact Cineform Support for assistance with this strange situation. I created a test DVD from an AVI file from the same timeline source proj. as the m2t file came from and the audio is fine, no dropouts whatsoever.
I think that I have a bug in my system, as I have had many strange things happen since finishing an edit. Such as Unable to open, file damaged dialogue box open when I just was working on the proj, to mysterious audio tracks not playing, except when I unlock the tracks (audio plays but Video disapears when in play, but is visible at stop and in scrub mode. In the middle of one viewing session, not even editing, P/Pro had to shut down. I had been running AVG Virus Protection, and have since learned that this is a NO NO with Cineform. I Uninstalled it, with a continuation of the same strange things happening. Every time I turn the computer on it is something new... My plan is to try to complete the proj that I am finishing up on, create some good DVD's, hopefully be able to Record back to tape w/o audio problems and have some kind of archive of the project!!! I will then Defrag/Restore the C Drive, hopefully my media files and project files on my D Drive will survive. Sorry about my wowes Dr, David, but what Anti Virus is compatable with the P/Pro-Cineform combination? Thanks again, Gary |
I use AVAST for my anti virus on my home Aspect HD system (free for non-commercial use.)
| All times are GMT -6. The time now is 09:08 PM. |
