-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Aspect V5 (https://www.dvinfo.net/forum/cineform-software-showcase/92961-aspect-v5.html)
Ray Bell May 1st, 2007 08:20 PM
Aspect V5
Cineform just put up the new version of Aspect ... its ready for downloading
and seems to work well... they also added MOV... and other goodies
David Newman May 1st, 2007 09:26 PM
Thanks Ray,
I normally post the info on the new builds, but we've been completing so many I forgot. There are new revisions of everything.
Aspect v5.0
NEO HDV/HD/2K v3.0
Prospect HD/2K/2K-ingest v3.0
We till have lot of website work to complete to explain all the new goodies and why everyone should upgrade. :)
Ian Savage May 2nd, 2007 09:05 AM
Hi David
Can I use v5.0 with PP 1.5.1 ?
Ian
David Newman May 2nd, 2007 09:43 AM
Yes, it will work fine with Premiere Pro 1.5.1, 2.0 and CS3. Download the trial and see for yourself.
Ian Savage May 2nd, 2007 09:54 AM
Thanks David
I'm a fully paid up Aspect user, just wanted to check I could use the latest :-)
Actually I'm having a problem at the moment converting some 1080i HDV CFHD files into PAL quicktime files through PP (Using H264), the shorter files (15mins) work fine but the 60min files are failing at the mov compiling stage, I'm just trying a 43min file to see what happens.
Ian
David Newman May 2nd, 2007 10:18 AM
Subject for another thread, Premiere's QuickTime export problems, we don't think it is CineForm related.
Regarding the new product releases. There is will be a 15-day trail as always, which I recommend you use. For upgrade pricing please read http://www.cineform.com/SpecialPricing.htm
Douglas Turner May 2nd, 2007 10:56 PM
I'm a fully paid-up v4 devotee - and keen to try v5, but less keen to spend another $100.
Assuming I have to uninstall v4 and install the v5, what will happen after the 15 day trial? I won't be using HDLink etc, just importing, editing and exporting to CFHD avi's.
OK, so I could uninstall v5 and re-install v4 with my Key, but I'm wondering whether that's necessary?
David Newman May 2nd, 2007 11:09 PM
Uninstalling v4 will not remove its license key. You have safely experiment with v5.
Douglas Turner May 2nd, 2007 11:24 PM
Cool - will do...
I'm still getting problems with PPRO3 and Aspect v4 - so will try v5.
I'm editing a feature in time for a test screening at the end of May, so unfort don't have much time to report issues at the moment... I just work-around them.
Wayne Johnson May 3rd, 2007 05:46 AM
Does v5 mean Aspect HD v4 will never be supported under Vista?
David Newman May 3rd, 2007 07:49 AM
Not necessarily, if the updates can be easy retrofitted we will do that.
Wayne Johnson May 3rd, 2007 09:47 AM
Good, because I don't think I need any of the v5 features. Unless..."Additional visual fidelity upgrades in the CineForm Intermediate codec" are noticeably better to the average eye?
Steven White May 3rd, 2007 05:57 PM
Out of curiosity, does the $99 to upgrade to Aspect 5 also apply to Aspect 3.2 owners?
-Steve
David Newman May 3rd, 2007 06:20 PM
Yes, from any version of Aspect HD it is $99. Also remember you can directly upgrade Aspect HD to the latest Prospect HD for additional $301.
John McGinley May 3rd, 2007 06:30 PM
I upgraded my aspect HD to prospect HD yesterday, next stop Intensity Pro card.... is that full raster HD I see recording on my computer? Oh, yes it is. Should make pulling green screen much better.
David Newman May 3rd, 2007 06:55 PM
Yes, thank you John. There have already been a bunch Aspect HD users to join you in Prospect HD in the last couple of days. We hope for many more.
Marc Colemont May 4th, 2007 08:54 AM
Hi David,
Is there an update log available between the V4 and V5?
I don't see any on your website, unless I overlooked a link?
David Newman May 4th, 2007 09:31 AM
With the site updates that may have beeen missed.
Keying elements :
1) New codec for even higher quality (using the Prospect core.)
2) HDSDI/HMDI capture support with HDLink using a range of AJA or Blackmagic cards.
3) Quicktime support for import and exports.
... plus more..
Marc Colemont May 4th, 2007 10:37 AM
Thanks David for the fast respons as always.
Douglas Turner May 4th, 2007 01:10 PM
So looking at those v4 to v5 updates, I won't see any quality improvements for my current project, where all the footage is already captured?
David Newman May 4th, 2007 01:29 PM
Douglas,
The codec upgrades are primarily encoder changes, so any new encodings will benefit. This includes CineForm exports from Premiere/AE of your existing projects.
Douglas Turner May 4th, 2007 05:09 PM
OK, thanks. We have a test screening at the start of June, so I'll delay trying v5 until then...
Marc Colemont May 10th, 2007 02:24 AM
Hi David,
I installed the AspectHD V5 trial, and imported some MOV trailer clips I downloaded from the Quicktime Pro website to have good MOV footage to convert as a test. (shrek3 trailer 720P)
But when I start the conversion the debugging displays an error on the MOV-file were the codec is not supported.
The Move-file plays fine on my laptop, and Premiere Pro 2.0 can read and convert it to Cineform. Do I need to install something extra from Quicktime? I have the Pro 7 installed.
David Newman May 10th, 2007 09:20 AM
Marc,
Some QuickTime files will not convert with HDLink as the decoder is not available in DirectShow, even if it is available to QuickTime, many codecs are available to both. If you can play the MOV in MediaPlayer when it should convert. We do plan to add full QuickTime based conversion support to HDLink to address this, although it is a low priority as there are work-arounds like you have found with Premiere.
Marc Colemont May 16th, 2007 08:32 AM
Thanks for the info David.
Is there a list of Quicktime codecs you currently support? Because I have a few clients in the Non-video business who needs to convert many quicktime media into AVI for our media servers. Adobe premiere and Procoder have too many settings for them. I would like to recommend to buy Neo HDV instead when it works with all kinds of Quicktime codecs.
David Newman May 16th, 2007 09:19 AM
Once we complete the QT interface to HDLink we will support the decoding and conversion too CineForm for anything QuickTime can handle. Today the QuickTime support is about using CineForm compression with QuickTime, which widens our compatibility greatly.
