-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Neo HDV - Worse Performance than m2t on timeline? (https://www.dvinfo.net/forum/cineform-software-showcase/94477-neo-hdv-worse-performance-than-m2t-timeline.html)
David Newman May 22nd, 2007 08:40 AM
Chris,
That should not have happened if the trial was still active. Did you install NEO Player at any point?
Chris Barcellos May 22nd, 2007 09:13 AM
Originally Posted by David Newman (Post 683738)
Chris,
Yes, I did install Neo Player about half way through the trial.
David Newman May 22nd, 2007 09:21 AM
That is way it is not encoding. Uninstall NEO HDV and the player, then reinstall NEO HDV, you will get your encoding back.
Chris Barcellos May 22nd, 2007 10:26 AM
Okay. Thanks, David.
So since we are on subject. I installed Neo Player, thinking I would have a stand alone player for Cineform stuff. Since I saw no stand alone program, I assume what happens is we are getting a codec that works with the various players.
So is the player only for those that don't have Cineform on board ? Sorry if this has been asked before.
David Newman May 22nd, 2007 10:48 AM
Yes, it probably should have been called CineForm Decoders rather than NEO Player, there is no need for custom player app as it works with most tools.
Douglas Turner May 23rd, 2007 11:04 PM
Doesn't work with VLC, which is my fave! Any idea why it doesn't?
Richard Leadbetter May 24th, 2007 01:01 AM
It's a VLC problem, not CineForm. VLC relies on its own internal decoders.
David Newman May 24th, 2007 09:07 AM
Yes, VLC doesn't use DirectShow or VFW base codecs, which is unfortunate.
Richard Leadbetter May 24th, 2007 03:02 PM
Media Player Classic does work however, and on systems where the CPU is stressed by CineForm playback, I seem to get marginally better performance using it.
