David, any NAB teasers
Anything you can share?
Hints are good too :D |
This year is the first time we have a booth (SL7826), it is small but not in a bad location (very near Apple.) Normally we have a distributed presence, appearing in multiple locations (partner booths like Sony, Canon, JVC, Adobe & Microsoft.) We are still in some partner booths, but it nice not to have so much running around. We will be showing lots cool stuff, with new stuff like MacOS support, 4:4:4 12-bit compression, new Adobe stuff, HDMI RT capture, as well and the latest for CineForm RAW at 2K (and maybe 4K if we have some nice footage) all running RT will the latest Intel procs. I think we will be spilling into the aisle.
I remember a suggestion on this forum in the dim and distant past for 4:4:4 CineForm, but I had no idea it was going to be implemented. Will this be rolled out into a super-high Prospect product, or will it be a function of the current Prospect codec?
I wish I could be visiting NAB to see all this new stuff for myself. |
The details of the 4:4:4 roll-out are still under wraps. However I expect/hope you will be happy with the plans.
latest beta oddity
ProspectHD-EditOnly-2.3.3.113-Setup.exe
whats this?:when starting PPRO2 OMP abort: Initializing libguide40.lib, but found libguide40.lib already initialized. This can cause performance degradation. Set environment variable KMP_DUPLICATE_LIB_OK=TRUE if you want your program to continue in this case. Then it either crashs or just goes away.. |
Don't you send that to support? Sounds like an issue with the Intel threading libraries, i.e. pretty fixable.
nevermind David I found an offending file.IT had copied directories looking at something else.....so I had 2 libs in filters folder
That is the last time they touch my stuff |
HDlink
Something is wrong in HD Link David..
if you start one capture via Hd Link, and stop it it stalls at second encode |
Need more documentation, but not here, please file a trouble ticket with the repeatable steps.
HdLink
tried to convert a CineForm avi from FS1 to low today in hdlink.
It refused to put it in the folder I wanted (select aint working) just a heads up. doing a mov is a small workaround |
Please, file a detailed report with support, as I don't really understand.
oppssseee goofed
Messed up today capturing via Firewire on my laptop with cineform in PPRO2.
I mis-judged the size of the file to hdd space. So after capturing the file, during the re-encode cineform ran out of space and I lost a half hour of the avi, but I have CineForms .tmp files still. David is there way/utility to attempt to re-re-encode the temp files after the fact? |
Rename the tmp file to *.m2t and you should be able to convert it.
Figured that was the case, BTW what is the other tmp file?Data? |
Which file? I only know of the one file.
CineForm question
Can you capture via Intensity Pro from the Component?
Yes, although I haven't personally tested that feature.
Thanks, so its possible it may be buggy or just go away on driver updates?
Blackmagic have been rev'ing their drivers fast, yet I haven't heard of any issues regarding the analog.
David, can we get a previous builds?
Can we on looking at “updates e-mail” get a previous builds list, from inception to current, with a bugs list per build?(or a combined Zip to keep on computers)
Just in case we need something that doesn’t work in Current build. |
No we don't have that, we only keep the last few builds online, with 6 shipping packages that we update monthly, our web server would have run out of space a long time ago. In the office we have every build we ever made. The readme file includes all the new features and major bug fixes included with every build.
Salah, make it a habit to keep your own archive of each build, or at least the previous install in case the new one fails and you have to step back in order to get work done. (I've only had to do this once). Typically you should not update in the middle of a project unless the specific build is addressing a fix to a current issue.
| All times are GMT -6. The time now is 11:31 PM. |
