Nanoflash For Video Presentation
Hello Mike & Dan,
I know this is not your intended use for the NanoFlash it's just the way things have worked out, I have a corporate video presentation to do. In the past I have used DVD or played directly from my laptop. I had to show the manager in charge of this project some of the acquisition vision from the Nanoflash to get approval to use it. Rather than burn files to disk I took the NanoFlash and my Sony HD 1080i panel for the preview and boy did I get the WOW factor, talk about raving on. I was asked if I could show that quality for my presentation to the board. I said I would see what I can do. Well here I am trying to work out the best way to do it. I usually do not like to make extra work for myself but this occasion the reaction was so positive that I have no option if I do not I will have very disappointed client. I intend to edit the presentation in FCP and export the sequences using EX-DCAM 1080/50i. Then use your File Convertor to make the EX-DCAM file to copy to the CF card for the NanoFlash. Well that’s my theory I can’t prove it at the moment because I am waiting on more CF cards stock to arrive. My supplier has suddenly run out of stock, he said he has been getting large orders for the Sandisk Extreme Pro CF cards and he thinks his price is too cheap. I think “the CD announcement that they are approved has got something to do with it.” Have I got the process correct and can you offer any advice? Many Thanks |
Dear Lance,
Yes, you have the process correct. I am having our expert review your workflow. I just checked with Tommy, our expert on the File Converter. Tommy will be posting shortly with more information. |
Hello Lance,
Our FileConverter has 2 main features: > copying un-edited, originally recorded nanoFlash / XDR files (which, for example, are not on their original CF card anymore) onto a CF card for playing out of nanoFlash / XDR. We have this because the Mac Finder copy can sometimes fragment files in the copy process, which we can't handle, so we provide a non-fragmented copy. > the 2nd feature is the one you'll want, and that is conversion of Final Cut Pro exported files to files which the nanoFlash / XDR can play. The converter has the following requirements: - the exported FCP files have to be either XDCAM 422 or XDCAM EX. - the exported files must be 30 Gbytes or less in size. Files greater than 4 Gbytes are broken up into 4 Gbyte increments in the conversion process. This 2nd feature makes a nanoFlash / XDR compatible .MXF copy of the files. (It can, incidentally, make .MXF copies of originally recorded files as well. ) So if you choose a CF volume as the destination folder, the files will be written out to the cards for play out of the nanoFlash / XDR. You will also want to disable record (System->Record Trigger->None) on the recorder if you want to play copied / converted files, so as to prevent accidentally over-writing your copied / converted files ( during record on the nanoFlash / XDR we will ignore and write over any copied files). Also note that edited, exported FCP footage (XDCAM 422) is encoded at 50 Mbit, even if recorded originally at higher bit rates. I don't know how it works completely but I think FCP only re-encodes the parts of the timeline that are edited in some way (if the timeline settings match the export settings, that is), so the un-edited parts of the timeline are not re-encoded during export and thus retain their original bit rate. I believe that is how it works. If the timeline video settings don't match the export settings then everything gets re-encoded, most likely. Tommy |
P.S. You could try to setup a full uncompressed HD project and set all your transitions and effects to render same, then output that to what you want. I haven't actually tried this yet, but I will report back when I have because I need to know this myself. |
Dear Mark,
In Final Cut Pro, tests have shown that there are cases where everything does not get recompressed. If one has our 100 Mbps footage placed on a Final Cut Pro timeline (set for 50 Mbps XDCam), then only footage which has been changed will be recompressed. |
....Now having stated this, I don't know if this would be the case for a full uncompressed HD timeline and setting all effects as same resolution (If you can ?). Even if FCP only recompresses what you change on the timeline, then that's still degradation at those points- Although I doubt you could see it. |
Dear Mark,
Barlow Elton posted this on August 15, Post 29 in "Received the nano/Testing/Rocks": Believe me, I am aware that rendering causes the bit rate to conform to whatever the codec dictates in a FCP timeline, however, what I've found is that unrendered high bit rate nanoFlash files do keep their original quality, even when editing in a XDCAM 422 50mbs sequence. And I don't mean that in the sense that they look fine, but that they actually export as self-contained QT movies with the 100mbs rate. I didn't get any render bars on footage that wasn't filtered, etc. If one does not make any changes to the clips, such as color correction, or anything else that would require it to be rendered, it appears from Barlow's comments above that FCP just copies the clips to the output. But if it has to be rendered, then it is currently rendered at 50 Mbps. What makes this possible is that FCP thinks our 100 Mbps footage is 50 Mbps, and that the output is 50 Mbps, so it appears that our footage without changes, does not appear to need rendering. All of this seem temporary to me. Apple, could easily, in my opinion, set up a 100 Mbps option for output. |
Thank you all for you suggestions.
I had forgotten about the re-compression issue with FCP, I recently upgrade to version 7, looks like I will have to try editing in uncompressed mode? Mark - I have been using NLE’s since the introduction of Media 100 version 1 and when Media 100 dropped support for the PC I had to find a replacement system. I have a friend who edit’s using Avid Media Composer and he gave me a quick demo. I just could not get my head around the interface and some of the terminology. I found the switch to FCP very easy and terminology was very similar. Toady Avid Media Composer looks like a very different animal, I should see if I can get a demo version for the Mac Pro and try it. After all I do want to retain the quality vision through the whole editing process and if FCP can't do it then hello Avid Media Composer. Dan - I do see your point that only the vision that has been change will be compressed. The type of work that I do require a lot of graphics and supers, sponsors logo’s etc to overlay that covers eighty percent of the timeline which means that just about everything is going to get compressed. Looks like I will have to get more info on Avid Media Composer and consider it very seriously. Tommy – Will file converter span files over two cards like the record process where we switch slots. I gather that file name protocol is handled the converter during the copying process to the CF cards. |
I'm not sure if you guys knew that FCP will output your timeline, without recompression, if you use the media manager. If you recorded in 100Mbps long GOP, then that's what you'll get out of media manager. I've tested this before but now you guys are going to make me test it again.
Ok, I just re-read your post. I also verified that media manager does in fact output full resolution files. If you record 100Mbps, that's what media manager will output. If you're to output a finished file though, media manager won't work.
My camera's files MUST be color corrected so I've already gotten used to using media manager and also gotten used to transcoding to ProRes422. |
Does the file converter work on the PC?
I use Edius and there is probably a file format that I can output that works with the converter. |
Dear Tim,
No, not at this time. We intend to have a version for the PC in the future. Our File Converter does multiple things, based on what is requested. One is to convert ".MOV" files to ".MXF" files. We need to work on the conversion from ".MXF" to ".MOV" before we port the finished program to the PC. Background: At this time, one can record in Quicktime (".MOV"), then use the File Converter, on a Mac, to obtain ".MXF". But, if someone accidently records ".MXF", then it the footage has to be played out of one unit into another to obtain ".MOV". Thus, we want to add this option as soon as possible. |
O.K. Thanks
Hello Dan & Mike,
I just played back a HD file recorded to CF cards via file converter and the audio is still out of sync. Cheers |
Dear Lance,
Could you please provide some more details so we can duplicate it in our lab, then correct the code? QT/MXF/MPG Long-GOP or I-Frame Only Bit-Rate Audio Setup: Embedded or Analog, Number of Channels of Audio |
Hi Dan,
I have a sequences in FCP EX-DCAM 1080/50i which I exported to quicktime. Then used CD's File Converter version 1.1 to write the file to the CF card for the NanoFlash to play back for a presentation. When I played back the quicktime file audio is in syn and when I playback from the CF card and the NanoFlash (Beta Version 1.5.31) audio is out of sync. It looks like about 2-3 frames out I was under the impression that this issue was going to addressed in the release of Beta Version 1.5.31? Many Thanks |
Dear Lance,
Our chief engineer was working on the audio sync issues today. I do not, at this point in time, know the results. I do know that we are trying to get the audio sync right for all flavors. |
Dear Dan,
Thank you for the update and would you please let me know when the audio issue is resolved and I will try again, in the mean time it's back to the old way for presentations. |
| All times are GMT -6. The time now is 01:34 PM. |
