nanoFlash Known Issues
Here's our latest list of known nanoFlash issues we are trying to resolve:
1) A/V Sync issues with some Tape-Based Cameras, especially with Panansonic VariCam. The sync seems to get off during tape shuttle operations. We are testing a potential fix today. 2) SanDisk Extreme III cards limited to 140 Mbps. We had orginally speced this card for 160 Mbps, but found some performance issues. The next firmware release will improve the Compact Flash card write performance by 15 to 40% depending on the card. So, the Extreme III will then be approved for 160 Mbps. 3) SDI output does not power-up when coming out of power-save mode. The only remedy is to power-cycle the nanoFlash. The short-term solution is to disable power-save if you need to monitor the SDI-Out. This will be fixed on the next release. 4) Problem locking to some SD-SDI sources, such as the IOHD. We are investigating this issue today and expect a fix shortly. 5) I-Frame only does not work in Vegas. We have files into Vegas engineers for testing. 6) Long-GOP above 50 Mbps is not recommended for Avid. However, all I-Frame-only files (up to 220 Mbps) work great in Avid. We have files into Avid engineers for testing. 7) Time-Lapse mode can produce very short files, espcecially for time intervals > 1 frame every 5 seconds. This will be improved on the next release. We welcome any additonal comments or bugs we may have missed. Note that most of these issues also apply to the Flash XDR, which will also be corrected. Best- |
Hi Michael,
I see that you are checking the ioHD issue. I think there is a Gamma discrepancy between the MPGs and the MOV files. Captured the same stuff (Prores p720 from the ioHD) the MPG file looks much darker than the MOV. IMO the MOV is correct. I haven't made further tests. Thanks for taking care of so many things. Best, rafael |
On the Gamma discrepancy issue, was the video captured via HD-SDI out of the nanoFlash into an IOHD? Is the bit-rate the same for the MOV and MPG file formats? I though the essence (MPEG2 data) was the same for MPG, MOV and MXF. But we could have made a mistake in programming the Sony MPEG2 encoder in MPG format. Thanks- |
Sounds like the usual QT nonsense between Apple/PC.
MOV files have a flag that works with the PC platform (gamma 2.2), but not going to MAC (1.8). Odd Apple makes this work OK on the PC. |
Dear Gints,
We are referring to the current SanDisk Extreme III cards. These have 30 MB/s on the front of the card. I was not aware that SanDisk originaly made a lower performace card with the same name. |
Good question. I was referring to the newer "30 MB" model. The older Extreme III cards were much slower. There is a basic speed test in the latest version of the nano/XDR firmware. Basically, you can test any card by setting the bitrate to the highest level (220 Mbps I-Frame). Then insert the card and hit record. If the card is not fast enough to keep up, the firmware will automatically drop back to the next slower rate. Note that this may take a few interations, as the bit-rate will drop from 220 -> 160 -> 140 -> 100 -> 50 as necessary. Also note that video recorded at too high a bit-rate will not be usable. Higher write performance will be included in the next firmware release (scheduled for the end of this month). Best- |
We found the problem in standard def with the IOHD. It was a mistake in our code and will be fixed in the next firmware release (due in about 2 weeks). Best- |
Mike, I think it's pretty timely that you're posting this. I need to record some SD material from a component video source today. I was planning on using my AJA IO (Not the IO HD) to connect to my component video source, and then use my XDR to record the SD-SDI output signal of the AJA IO.
Do you know if the problem you are referring to above affects the AJA IO, or only the IOhd. Also, I'm working with an XDR, not a Nano if that makes any difference. |
If you are not using embedded audio, then you should be OK. But we have not tested with the IOHD, so cannot confirm with 100% confidence. I would highly recommend that you test as early as possible (so you have time for plan "B", if necessary). This should be fixed for almost all SD sources in the next update. Sorry for any problems this may cause. Best- |
Dear Mike,
Just to be clear, Aaron is using an AJA IO, not an IO HD. In either case, Aaron is testing his setup tonight. |
Here is a speed comparison table for the Nikon D3. The write block size may have something to do with higher RAW performance, but we can't tell. I'm not sure how well this table applies to the Nanoflash, so it would be could if CD would create a similar table. Rob Galbraith DPI: Nikon D3 |
When connecting the SDI to the XDR, the XDR shows NO SRC. The XDR also is very sluggish to respond to any button pressing while the AJA IO is connected via SDI. Hopefully, your fix for the IOHD also fixes my problem I see here. Every once in a while, I need to record an analog component SD source. I'll continue to use the AJA IO with a MacBook Pro and FCP. It's a workable solution, if not a finicky one. I was hoping the XDR could do this and save me the headache of dealing with a laptop to capture with. |
Great suggestion! I'll speak to our engineers next week about developing a simple program to check the write/read performance of a CF card. I can envision a couple of different techniques. We'll need to requalify almost all CF cards after we release our new write algorithm later this month. All the cards we have tested have shown some improvement ranging from 10 to 40%. Best- |
HD-SDI vs. HDMI
Should I be getting a different picture quality when I use the SDI vs. the HDMI inputs? We are capturing video game footage out of a XBox 360 going into the nanoFlash via HDMI. The editors were complaining of crushed blacks. I switched to the SDI input and all is well. The new signal path is HDMI out of the XBox into a nanoConnect, out of the nanoConnect HD-SDI into the nanoFlash. Is this a known issue? Any thoughts on why this is happening? Here's my setup:
XBox 360 HDMI out to nanoConnect HD-SDI out to nanoFlash 1.0.112 SanDisk Extreme IV 16GB LongGOP, 50Mbps, MXF Import to Avid 4.0.2 Unfortunately I don't have anything that can generate bars that has HDMI output. Please advise... |
Can I make a guess?
Gamma? 2.2/1.8? Otherwise, something is perhaps looking for setup which shouldn't be in this case, but it sure is indicated. |
Dear Ted,
I have alerted our Support Manager. You have provided us with the detailed information that we need to try to solve your problem. We will report back. |
So the video looks correct if you go HDMI out of the XBOX -> nanoConnect -> nanoFlash? If so, we have an incorrect color space conversion table loaded into the HDMI receiver on the nanoFlash. This should be an easy fix. Best- |
The video looks better XBox->nanoConnect->nanoFlash. There are more details in the blacks and dark areas of the shot. I would hate to say correct as I don't have a way to bring in bars via HDMI. I recorded some test bars out of the Avid via HD-SDI and played them back into the scopes and everything tested out perfectly. Should be easy for you guys to throw some bars at it SDI and HDMI and see if there's a shift. Please let me know what you find out.
Gamma discrepancy
Sorry I've got lost in this thread. No. The discrepancy was capturing from the ioHD to the NANO. I played in the MBP through the ioHd and captured in the NANO a 720p50 clip. I've captured as QT and as MPEG. The MPG was much darker. Best, rafael PS: Great you found the ioHD bug. |
Hi Dan & Mike,
I tested the AJA IO HD connected to my DVCAM player via component sending a HD SDI signal to the NanoFlash. I found it worked fine but too big to mount onto my dockable camera so I have purchased a Black Magic Design Mini Analogue to SDI converter which I am installing and testing tomorrow to record SD to the NanoFlash. Today I used my new portable SDHD SDI monitor for the first time. When we finished shooting our links I decided to check the recording and do a playback. When I pressed play on the NanoFlash I noticed no audio levels, well it scared the hell out of me then I remembered reading somewhere that it was a known issue. The monitor only has an earphone socket, when I put the headphones on to my great relief and audio was there. Do you have any idea when SD playback will be implemented. Thanks |
Dear Lance,
Our audio level meters in playback were intermittent. On a regular basis, they would go to zero, then return to showing the normal levels. We decided to stop showing the level meters on playback until we could fix the problem. I am sorry that this caused you some concern (actually a major scare). I know we are working on SD Playback, but I do not know the schedule at this moment. What is, or is not going to be in our next release changes quite frequently, so I have a hard time keeping up. For example, I discussed "Low Latency audio", for audio embedded in the HD-SDI stream two days ago. Last night I was surprised to find out that this is expected in the next releaes. (On the nanoFlash, analog audio is already "low latency".) |
Thanks Dan as long as it record audio that's fine, I seldom look at the Nano during playback. My HD/SD monitor has the option to display's audio levels which I have now switched on and when I playback via HDMI or SDI I can see the audio from the Nano.
Just as a follow-up on the color issue with the HDMI out of the XBOX, we were able to duplicate the issue in our lab today. We see the problem with the crushed blacks and were able to make a fix to our firmware. If you would like a beta copy to test, please send an e-mail to support at convergent-design.com. Otherwise it will be included in the next firmware update. Best- |
Great news! Thanks, Mike. Does that mean you got an Xbox for the lab? You know... For "testing"
One of our guys in manufacturing area brought in his XBOX as a temporary loaner, it cost us a BBQ lunch, but it was worth it. Best- |
HDMI Issue still present
Hey Mike,
I just updated the firmware on our units to 1.1.150 and I'm still seeing this issue with crushed blacks when using the HDMI input. Any thoughts? Is this only on the HDMI output of the XBox? This time I'll take you up on that beta testing if it's still an option. Thanks, TedO |
Whoops! Just looked at the firmware notes and it mentions "HDMI input color setting menu option" Going to go check that out. BRB!!
That did it! Setting it to the Legal setting works great and now the signal is identical to the SDI input. Thanks for the fix!!!
| All times are GMT -6. The time now is 01:49 PM. |
