Nano HDMI to Feed Monitor
Trying to use the Nano HDMI out to feed a SmallHD DP1 montior.
Can't seem to get the settings correct - monitor keeps saying No Source. However when I use the Component connections direct from the XHG1 camera, I am ok. So I am doing something wrong with the Nano settings. What would be the correct settings? |
I don’t know your monitor but heres a quote from the latest nanoFLASH manual;
Record/Play PSF-checked and E to E checked, - if you are shooting/recording progressive. It works like a charm. You may wanna see if the settings on your DP1 are for HDMI signal.
You are correct Paul. I didn't unchecked E to E when I switched to HDMI and now when I looked at the settings it was checked of course. It seems its irrelevant to the HDMI if E to E is checked... Cheers
Now set the DP1 to display maximum picture area. Great monitor. Mine is also HDMI fed from NanoFlash.
| All times are GMT -6. The time now is 04:04 PM. |
