-   Convergent Design Odyssey (https://www.dvinfo.net/forum/convergent-design-odyssey/)
-   -   NanoFlash will support 8-Channel Audio (https://www.dvinfo.net/forum/convergent-design-odyssey/472172-nanoflash-will-support-8-channel-audio.html)
Lance Librandi February 3rd, 2010 12:27 AM
Hello Dan,
In another thread you said "Our Chief Engineer has 8-Channel audio working also, so this, any many other features will be included in this Public Beta". This is great, I can certainly make very good use of these extra channels in my work.
Question:
Given the limited number of inputs on the EX3 camera which has two audio channels which most camera's have, how do we in the real world get access to send the extra channels to the Nanoflash?
Many Thanks
Gints Klimanis February 3rd, 2010 11:36 AM
For starters, the Nanoflash would merge its stereo analog input with the input from the SDI stream. For EX1/3 users, that's an easy four channels.
Dan Keaton February 3rd, 2010 02:17 PM
Dear Lance,
There are multiple ways to look at our upcoming 8-Channel Audio capability.
1. For acquisition, we can take the channels that the camera provides, 2, 4 or more, via HD-SDI or HDMI into the nanoFlash.
Then we can add two channels of analog (once we have this feature working).
If one's camera has only two or four channels, one could use an HD-SDI audio embedder to feed the nanoFlash more channels.
2. For delivery.
One can create up to 8 separate channels in your NLE, then output this via HD-SDI or HDMI to the nanoFlash for delivery.
Lance Librandi February 4th, 2010 02:26 AM
Thanks Dan,
I am very interested in the HD-SDI audio embedder, that will allow me to embed 8 audio channels plus SDI video. Would you be able to suggest one that would suit the EX3 and Nanoflash setup. I really do not like the idea of using the mini TRS connector (tip, ring, sleeve), I have had them fail on other equipment in the past with constant use.
Hey what about CD developing a 8 Channel Analogue, AES and Embedded HD-SDI Audio breakout box?
Aaron Newsome February 4th, 2010 05:44 PM
Hi Lance. I have a Motu V4HD. That will embed 8 channels of analog audio into SDI. It's a rackmount though so not exactly portable. I've seen some little embedder boxes out there that will embed audio into SDI though.
Lance Librandi February 5th, 2010 02:19 AM
Hello Aaron,
"I was I was looking at the Motu V4HD as part of my studio kit but I found support was lacking. If you can remember what the "little embedder boxe" was I would really appreciate it I am looking for something that portable for live events and staging.
Many Thanks
Dan Keaton February 5th, 2010 02:48 AM
Dear Lance,
I have not researched this yet.
You may want to check out Miranda.
Andrew Stone February 5th, 2010 01:23 PM
How much is the Miranda box?
I spied [ this ] (effective) 4 channel (2 stereo) analogue audio embedder that looks good. It has balanced inputs which is good, however, I am pretty sure it does not supply phantom power. Have no idea what the price is for the unit.
Lance what do you mean "lacking support"? MOTU in my experience with their audio interfaces has been pretty darn good. There was a brief time when they had a bad reputation for driver issues but that period is long since gone. I have had 2 pieces of MOTU gear that I use every day and have for a few years. No complaints.
Dan Keaton February 5th, 2010 02:18 PM
Dear Friends,
AJA makes a Four Channel analog audio embedder:
AJA | HD10MA HD/SD (dual rate SDI) Audio Embedder / | HD10AMA
Lance Librandi February 5th, 2010 05:14 PM
Hi Andrew.
You are right it was during the time when they had a bad reputation for driver issues my AV supplier said the very same thing. I do like MOTU gear I use two MOTU Traveler's with repeaters and 60 meters of firewire cable to carry audio from stage my work station. Hey the 4461A SDI analogue audio embedder Mini Blox is the type of unit I have been looking for but with 8 channels.
Dan the Mini Blox is the type on device I have been looking for but with 8 audio channels perhaps CD would give consideration to producing a similar device that is user friendly and certified to work with the NanFlash.
I would buy it.
Andrew Stone February 5th, 2010 06:22 PM
The AJA H10MA is a nice unit for the price. Fair price I would say at B&H's discounted cost which is presently at $850.
Checked the tech specs on B & H as well as AJA. You would have to have a mixer with phantom power capabilities to add mic power for your powered condenser mics. So add at least another grand or two for a decent portable mixer unless you already have one or a soundman to handle that.
Dan Keaton February 6th, 2010 01:34 PM
Dear Lance,
As an location sound person, I would love for us to come up with the following device:
1. 8 or more channels of input.
2. Balanced XLR inputs.
3. Selectable Phantom Power for each input.
4. Gain and Trim for each channel.
5. Great meters.
6. Great Headphone monitoring
7. The ability to accept an HD-SDI signal for input, then embedded the above audio channels into the signal, then output the HD-SDI with the embedded audio.
To be realistic, we are very busy adding features to our line of HD/SD recorders.
Also, I just love Sound Devices' gear.
I wonder if, for many applications with this many audio inputs, wouldn't there be an audio person involved, with the appropriate audio gear, to record the sound separately (Dual System Sound)?
Daniel S. Melius March 1st, 2010 12:33 PM
Originally Posted by Dan Keaton (Post 1482103)
Dear Friends,
That is a nice device there you posted. It looks like I would be able to get four channels into the nanoflash SDI from the Sound Devices 788T using the AJA embedder and using four sound Device TA3F to XLR cables.
Daniel S. Melius March 1st, 2010 01:24 PM
Correction to my last post as 6 channels can be sent from the 788T as I forgot about the 3.5mm analog unbalanced channel output for channels 5 and 6 on the 788T that would go into the 3.5mm input of the nanoflash.
It's to bad that the AJA can not be battery run though according the description on B&H photo.
Adam Stanislav March 1st, 2010 02:29 PM
Or, for half the price, you could get http://www.bhphotovideo.com/c/product/620833-REG/Blackmagic_Design_CONVMCAUDS_Mini_Converter_Audio_to.html, which does the same thing. It will "embed 4 channels of analog audio, or 8 channels of AES/EBU digital audio into any SDI video connection."
Daniel S. Melius March 1st, 2010 05:41 PM
Thanks for the link. It would just add an extra four cables I think for the 788T as I don't think they make TA3 to 1/4 mini cables. It would have to be TA3 to XLR and then XLR to 1/4 mini.
This unit is a great deal more compact. It's a shame that none of them have battery adapters made up for them eventhough they are so small. It looks like I'll have to get someone to make me up a custom NP-1 or Sony type NP-F or BP-U battery adapter for it.
It would seem to be the way to go to make sure that six of the audio tracks (4 going to SDI and 2 thru 3.5 mini from Sound Devices 788T audio recorder stays in sync with the video of the camera. With those six along with the two from the EX1, I would be using up all 8 channels on the SDI nanoflash stream.
Adam Stanislav March 1st, 2010 07:02 PM
You can get about any audio cable at Sweetwater. I use them for all my audio needs, as the first time I called them all I needed was a three dollar cable which they sent by Fedex free shipping. They have never charged me for shipping, no matter how much or how little I ordered. When I mentioned to the salesman how impressed I was by the free shipping for just a little cable, he said they know how important a cable is.
As for the battery cable, I wish all pro equipment used the same connectors, but they do not. Nevertheless, the one on the Blackmagic adapter seems a pretty standard power supply cable. You can probably order a battery adapter cable from B&H at the same time you get the device. They tend to know what needs what cable (and they are one of DVInfo sponsors).
Ron Aerts March 2nd, 2010 02:30 AM
Yamaha embedder
On live events Yamaha digital desks are very common in the medium and high end market. Often is there a slot in the desk available to put in this card: http://www.yamahaproaudio.com/downlo...rochure_en.pdf
with which the soundengineer can choose what audio source goes into what SDI channel. With a networkcable, laptop and the free studiomanager software you can make a full mix separately from the venue, without the need of big desks, signal splitters, recorders and complex syncstuff into any of the (NanoFlash) Channels
Awesome... let's doe this.
