-   Convergent Design Odyssey (https://www.dvinfo.net/forum/convergent-design-odyssey/)
-   -   Panasonic AF100 and Nanoflash (https://www.dvinfo.net/forum/convergent-design-odyssey/476978-panasonic-af100-nanoflash.html)
Ed David April 16th, 2010 04:39 PM
Jan Critterdon said that the uncompressed coming out of the HD-SDI port will work with the nanoflash . I think this 4/3 in camera combined with the nanoflash will be in essence the Red Scarlet everyone dreams of. Around 4k acquisition and ability to capture to a great codec that you can edit in 1080p.
Please I hope that I can hook your device up to this camera that's going to be as revolutionary as the DVX100 was back in the early days.
Henry Olonga April 17th, 2010 04:37 AM
Hey Ed - I believe that this is possible as Jan dealt with this. It is it's biggest selling point.This will make the camera a camera capable of capturing imgaes as good as what - close to what a Panavision Gensis produces perhaps?
I asked whether it was 8 bit or 10 bit and never got a direct answer - will ask again. So perhaps £ 5000 for the camcorder and £ 2300 for a Nano and you get a ready to shoot full HD powerhouse capable of producing stunning images. There will be no excuses now.....
Luben Izov April 17th, 2010 11:02 AM
Hi Henry,
I looked at this presentation the other day and yes is a very good camera and with the nanoFlash would be awesome! I think you would be able to find an answer to your questions just by watching this video...
FreshDV NAB 2010 - Panasonic AF100, 3D and HPX-370 at FreshDV
Bruce Schultz April 17th, 2010 12:16 PM
Originally Posted by Ed David (Post 1515325)
Around 4k acquisition and ability to capture to a great codec that you can edit in 1080p. .
Just curious, how do you get to a 4K acquisition with a codec (AVCPRO/AVCCAM) that only supports 1920x1080? The NanoFlash as well only records 4:2:2 XDCAM HD @ 1920x1080. So how do you get 4K? Are you assuming that the larger chip (APS-C or H) size gets you there, or is Panasonic telling you that the HDSDI tap will send out a 4K signal?
Dan Keaton April 17th, 2010 12:25 PM
Dear Bruce,
It was nice meeting you at NAB.
HD-SDI is either 1280 x 720 (720 mode) or 1920 x 1080 (1080 mode).
If a camera has HD-SDI then they have to output a signal that meets these standards.
If one has a 4K camera, and a HD-SDI output, then the camera must downres.
Rafael Amador April 18th, 2010 06:34 AM
Right.
That is what we want, but without the internal recorder system (16b audio?).
Good lens, good captor and processor, and HD/SD-SDI out; then the recorder of your choice.
With products like the NANO, Ki-Pro, etc in the market, i see the camera business slipping from the hands of the big manufacturers.
rafael
Henry Olonga April 18th, 2010 03:31 PM
Originally Posted by Luben Izov (Post 1515578)
Hi Henry,
Thanks Luben,but that does not give us an indication as to whether the HD-SDI is 8 bit or 10 bit unless I missed it.Too early to say perhaps. Jan keeps saying that H264 is the best longop codec out there.......I reckon CD have something to say about that!!!!!!
Best wishes.
Dan Keaton April 18th, 2010 04:47 PM
Dear Henry,
In our opinion, based on substantial field experience:
H.264 at lower bit-rates is more efficient than MPEG-2.
The nanoFlash gives you a very wide variety of bit-rates and quality choices.
The Panasonic camera appears to be limited to a maximum of 24 Mbps. We offer bit-rates up to 280 Mbps, up to 180 Mbps in Long-GOP.
It would be tough to argue that 24 Mbps H.264 is superior in quality to 180 Mbps Long-GOP, or 280 Mbps I-Frame Only.
But, most importantly, MPEG-2 is easier to edit.
Rafael Amador April 18th, 2010 11:44 PM
Best wishes.
As pointed by Dan, H264 is better than MPEG-2 for low data rate compression (web video like).
No advantage when you are working with enough data rate.
In fact h264 is much complicated to compress and de-compress than MPEG-2.
HD/SD-SDI output 10b YUV, and the "AVCPRO/AVCCA" can support 4K.
rafael
Henry Olonga April 19th, 2010 01:54 PM
Thanks for your input guys - my nanoflash produces images that absolutely smash the AVCHD of the HFS10 so I don't believe that H264 is superior when put up against Nanoflash's best bit rates. It's just not possible but perhaps she was referring to a given price and performance point.
Dean Harrington April 20th, 2010 03:46 AM
Af-100
Good to see Panasonic back on track with another, highly likely, industry uplight for indi-film makers. I think it's going to be very interesting next Fall with the Scarlet and this cam coming out.
Aaron Newsome April 20th, 2010 10:18 PM
I would bet the house that the AF100 H.264 is 8bit. It's a tossup though whether the HD-SDI is 8 or 10bit though. Doesn't matter with the nano or XDR though. 8bit is the best you can do.
Rafael Amador April 21st, 2010 12:50 AM
The H264 at 24Mbps is 8b 420.
No sense to make 10b or 422 at such data rate.
Cameras output 10b through the SDI.(the process is done at 12 or 14b).
How PANASONIC gonna put 8b SDI output, when 200$$ cameras output 10b Unc?
Panasonic knows that people look at this camera with something like the NANO or Ki-Pro in mind.
rafael
Aaron Newsome April 28th, 2010 09:39 AM
Yes you can have a camera that has 4k worth of data collected at the sensor, and it downrezes that data into a 1080p package in real time. Entirely possible.
Dean Harrington May 11th, 2010 04:54 PM
I remember ...
There was a system developed for the DVX-100 some years ago that took the image information directly from the censors and delivered high resolution images off that censor. Any one remember what happened that that delivery system and what it was called? I could be wrong but I believe it was 4.4.4 deliverable? I also recall it required a modification to the camera. The concept and/or technology was bought out from the original developer (seller signed a non-disclosure agreement I believe) by an unnamed company and the whole thing has disappeared from the camera making scene.
Pietro Jona May 12th, 2010 02:19 AM
It was called Andromeda. 4:4:4 out of a usb I think I remember.
Dean Harrington May 12th, 2010 05:43 AM
that's it ...
I wonder what the full story is on this as that was very promising!!!
Dan Keaton September 30th, 2010 11:17 AM
Panasonic AF100/AF101 + nanoFlash
Dear Friends,
These are exciting times as new cameras are coming out with larger sensors.
One example is the Panasonic AF100/AF101, which is generating quite a lot of excitement.
The image quality and versatility of the AF100/AF101 can be increased by adding a nanoFlash.
Here are some reasons to add the nanoFlash to the new camera, which is scheduled to ship in December.
And of course, the nanoFlash may be used with a wide variety of other cameras
and may be upgraded to nano3D, if desired.
• Improvement in Image Quality
......... 4:2:2 versus recording 4:2:0 in-camera
......... High-Bit Rate recordings
.............1. Up to 280 Megabits per second (Mbps)
.............2. In camera recordings limited to 21 Mbps Average, 24 Mbps max, AVCHD
......... Very low noise recordings
......... Free from Artifacts
......... Can handle excessive detail, excessive motion
• Versatility
......... Choose bit rate to suit your needs, 18 to 280 Mbps
......... Balance image quality versus recording time
......... May be used with a wide variety of other cameras
......... Many advanced recording options
......... Excellent Playback Device, far better than Blu-ray
• Fast and Easy Editing
......... Fast, Responsive Editing (more responsive than editing AVCHD)
......... Simple Workflow – Just Drag and Drop footage into your editor
......... Widely supported by all professional Non-Linear Editors
......... Free “Re-Wrap” tools: MOV>MXF for both PC and Mac
• Uses Lower Cost, Higher Performance CompactFlash cards
......... CompactFlash cards are much faster than available SDXC cards
• Long Recording Time
......... 5.3 Hours at Broadcast Quality 50 Mbps, 4:2:2
......... 2.6 Hours at 100 Mbps, 4:2:2
......... 1 Hour at 280 Mbps 4:2:2
• Supports Pulldown Removal and native recording
......... Records native 1080p29.97, 1080p25, 1080p23.976
......... Records native 720p29.97, 720p25, 720p23.976
• Supports Time-Lapse Recordings
• Supports Image Flip, Image Flop, Image Flip + Image Flop
• Supports Hot Swapping of CompactFlash cards
• Offers Redundant Recording Capability, in-camera becomes the backup
• May be upgraded to nano3D for Stereoscopic Projects
Jim Bridges October 8th, 2010 06:11 PM
Well put, my AF100 is on order. The only reason I am getting one is because of the HDSDI port for my Nano. I imagine the pictures will be fantastic.
Now to work on some clean looking powering options.
Mark Job October 8th, 2010 08:03 PM
AF 100/101 HD-SDI Output Spec
Hi Dan & Jim:
Does anyone know yet what are the preliminary output specifications for the HD-SDI on the new AF 100/101 ? I understand the internal camera recorder to be using the AVCHD Codec @ 4:2:0 color space (??)
Dan Keaton October 9th, 2010 11:01 PM
Dear Mark,
I understand that it is 4:2:2, 8-Bit.
Jim Bridges October 10th, 2010 09:16 AM
That is what I heard as well.
Jim Bridges November 2nd, 2010 07:15 PM
Nanoflash and the AF100
Any word if there is a SWIT-style battery with a power plug being made for the AF100. I am trying to cut down how many different batteries I will need for this camera. Thanks for any help
Ned Soltz November 2nd, 2010 07:24 PM
Since the camera doesn't ship until Dec 27, it is a little premature to see third-party accessories for it yet. I presume that we will see a ton of accessories given the anticipated popularity of the AF-100. What and when is the question.
Jim Bridges November 3rd, 2010 05:19 PM
Actually Ned, I am starting to see "3rd Party" assesories popping up as well as different price point camera packages. My question was if anyone has heard a battery available or in development for the AF100 that can run both the Nano or AF100. I apologize if I wasn't clear enough.
Dan Keaton November 3rd, 2010 06:28 PM
Dear Jim,
While it is nice to use one battery to power both, we are working on a nice, small, light-weight battery system for the nanoFlash so that the camera can be powered with its normal battery and the nanoFlash powered by a 3.8 ounce battery.
We are very enthused about the AF100/AF101 and we will fully support it.
The nanoFlash is an ideal companion to the AF100/AF101.
Jim Bridges November 3rd, 2010 07:56 PM
Great news Dan, thanks for the responce. Any price point or battery duration specs yet?
Dan Keaton November 3rd, 2010 09:03 PM
Dear Jim,
It will record about three hours.
It is our existing 2-cell Lithium-Ion battery and a soft-case for the battery.
The battery is around $60, I do not have a price for the soft-case.
