Recording 1080p 60 frames? - Page 2 at DVinfo.net
Convergent Design Odyssey
Old June 3rd, 2010, 08:00 PM   #16
You're Welcome :-)
Originally Posted by Andrew Stone View Post
Interesting read. I rarely read reviews on consumer level camcorders so it is interesting to see what is up and coming in this part of the market segment. Gives you a sense of where things are going in the next year or so with features to expect.
Thanks for posting that up Mark.
...Hi Andrew: You're most welcome :-) There's another brainless, el cheap, plastic lens - point and shoot camera worth pointing out (Although it does not do 1080 60p. I picked up a Kodak Zi8 pocket digital camcorder. This camera is a little over 162$ on line and produces absolutely phenomenal 1080 p 30, 720 p60 and 720 p30 along with SD video and records onto SD/SDHC memory cards and has an external stereo mic jack with full manual level control. This camera has its own editing software built into it and auto installs and updates itself assign as you connect the camera to your PC or MAC ! It's really worth mentioning.
Mark Job is offline   Reply With Quote
Old June 3rd, 2010, 11:40 PM   #17
Yep, Ikegami is priding itself as being part of the 1080 60p revolution.
Ikegami Press News
Paulo Teixeira is offline   Reply With Quote
Old June 5th, 2010, 02:22 AM   #18
Here's the other Ik__________
A-cam dII - The camera loves you | A-cam dII | Products | Ikonoskop
Old June 5th, 2010, 03:33 AM   #19
Does that Ikonoskop even exist yet? Seems we've been waiting for ever for it.
Add SI-2k to the list, that'll do 80fps at 2k I seem to remember.
Steve
Old June 5th, 2010, 11:06 PM   #20
Since they are also releasing a 3D version, I would think that the 2D version should be almost ready to sell.
A-Cam 3D | A-Cam3D | Products | Ikonoskop
Old June 6th, 2010, 03:14 AM   #21
Says July 2010 now, the guys on the forum at their site have been getting irate at the lack of news and the delays. July - I'll believe it when I see it!
Steve
Old June 6th, 2010, 10:30 AM   #22
The Sanyo does indeed record 1080p 60. But finding a computer to play back the AVCHD files...
Cineform can't convert the files, and no editor I know of can edit 1080p 60.
It's a very good quality camera for a consumer model, though. Alas, it is 35Mbps tops.
Regards,
Thane Silliker, London, Ontario
Thane Silliker is offline   Reply With Quote
Old September 9th, 2010, 09:58 AM   #23
Sorry for bumping, but Panasonic TM700 1080p60 clips can be edited in Sony Vegas Pro 9 no problem. But, the only thing that could play 1080p60 AVC at full framerate appears to be the Hardware Acceleration chips on the Nvidia Geforce GF100 Fermi cards (GTX 400 series). And even then, the Hardware Accelerator load is nearly 100%.
However, once the Nanoflash can accept 3G-SDI and can get a 1080p60 codec (Might want to try WebM even), then a 1080p60 NanoFlash is a possibility.
Edit:
From the WebM FAQ
VP8 uses 14 bits for width and height, so the maximum resolution is 16384x16384 pixels. VP8 places no constraints on framerate or datarate.
Just replace OGG with PCM and you've got yourself an open-source 1080p60 solution with unlimited bitrate.
Old September 9th, 2010, 08:18 PM   #24
"However, once the Nanoflash can accept 3G-SDI and can get a 1080p60 codec (Might want to try WebM even), then a 1080p60 NanoFlash is a possibility".
Although it seems that in theory is possible, i haven't see any implementation of MPEG-2 p60/50 at 1920 x 1080.
To get this kind of stuff is one of the reasons MP4 has been developed.
rafael
Rafael Amador is offline   Reply
