nanoFlash for Playout - settings..? - Page 2 at DVinfo.net
Convergent Design Odyssey
Old March 29th, 2011, 06:23 AM   #16
Re: nanoFlash for Playout - settings..?
Dear Jyrki,
Our File Converter works with Final Cut Pro files only at this time.
On other systems, playing out via HD-SDI, or even SD-SDI, to the nanoFlash is one way of accomplishing the task.
Of course, this requires your NLE to be equipped with a HD-SDI output port.
Dan Keaton
Augusta Georgia
Old March 29th, 2011, 07:02 AM   #17
Dear Dan
Thank you for the quick reply.
Please add an option for Premiere Pro to your File Converter, then.
Premiere has a long list of outputs to choose from, some of which should be suitable for conversion.
Jyrki Hokkanen is offline   Reply With Quote
Old December 25th, 2011, 02:19 AM   #18
Originally Posted by Tommy Schell View Post
Hi,
if you have originally recorded nanoFlash material that you wish to copy to a CF card for playing on the nanoFlash:
> you can use the "non-fragmented copy" option out to a formatted CF card.
If you have material edited in Final Cut Pro:
> in FCP, export the footage File->Export->as Quicktime movie, with an XDCAM profile (preferably XDCAM 4:2:2)
(do not export as 720p24, 25, or 30 - nanoFlash can not play these formats)
> using our FileConverter, use the "Convert" option, choose the formatted card as the destination (for edited footage, this step must be taken or we will not be able to play the footage) (HD only, SD not supported)
> then it should play out of nanoFlash
Tommy
Any changes to this since the advent of FCP-X?
Ron
ps Merry Christmas to all
Ronald Jackson is offline   Reply With Quote
Old December 25th, 2011, 02:37 AM   #19
Dear Ron,
Not that I know of.
Are you having problems?
Merry Christmas Ron!
Dan Keaton
Augusta Georgia
Old December 25th, 2011, 04:12 AM   #20
Cheers Dan,
No problems 'cos haven't tried yet but anticipating a few, not least operator ones,
Ron
Old December 27th, 2011, 02:06 AM   #21
I had a look on the CD Downloads page and "File Convertor" seems to have disappeared unless I'm looking in the wrong place,
Ron
Old December 27th, 2011, 02:28 AM   #22
I also note from elsewhere that this good only for 50Mbps recordings, whereas mine are 100Mbps,
Ron
Old December 27th, 2011, 06:58 AM   #23
Dear Ron,
Here is the link to the file converter:
Downloads | nanoFlash, nano3D, FlashXDR
Dan Keaton
Augusta Georgia
Old December 27th, 2011, 07:04 AM   #24
Thanks Dan,
Ron
Old December 28th, 2011, 10:18 AM   #25
I've installed the File Converter, converted my movie into XDCAM 4:2:2 format, connected a blank formatted CF card to my Desktop.
I have added my XDCAM movie as the source folder and added "/volumes/No Name/CLP" as the destination.
When I click "Convert" I get the message " Check the Logs in the destination folder".
I must be doing something wrong but what?
Ron
Old December 28th, 2011, 10:35 AM   #26
Dear Ron,
I will ask our support team to assist.
Dan Keaton
Augusta Georgia
Old December 28th, 2011, 02:00 PM   #27
Sponsor: Convergent Design
Hello Ron,
Are you exporting out of Final Cut Pro 7 or Final Cut Pro X?
Also have you check the error Log to see what the Error is?
Or could you forward the error to me, and I can try to replicate the issue.
Support | Convergent Design
Andy Mangrum, Tech Support Convergent Design, Inc
Andy Mangrum is offline   Reply With Quote
Old December 28th, 2011, 02:14 PM   #28
Andy thanks,
Video out of FCP X, and I don't know how to find the "Error Log", let alone forward it. Your further advice will be welcome.
Another thing I noticed is that my 100Mbps .Mov video, when converted to XDCAM 4:2:2 was about half the file size. Is this because of some 50Mbps limiter on your File Converter?
At the end of the day I'm looking to be able to project ,via my 1080p projector, edited video as near as possible to the quality I get when connecting my nanoFlash, with unedited footage, to my 1080p monitor.
Investigating both Blu Ray and Flash devices via a Western Digital Media Player. Hope C.D. can come up trumps as potentially a very elegant solution,
Ron
Old December 29th, 2011, 01:10 AM   #29
Andy,
Under "CLP" on the CF card I see "FileConvertorLog.txt" when I open this I see **NEXT LOG** and then a string, 6 , of "Unknown error : - 11
** NEXT LOG**
and so on, Ron
Old December 29th, 2011, 01:18 AM   #30
Re-formatted the card and tried again . Seems the six messages I referred to above each correspond to a click on the "CONVERT" button,
Ron
