I don't understand these costs for 2K raw with the Odyssey at DVinfo.net
Convergent Design Odyssey
Old May 9th, 2013, 01:52 AM   #1
I need help understanding how the Odyssey 7Q works with the FS700.
1. I understand that we will have to wait for Sony to upgrade the camera, there may or may not be a cost involved.
2. We have to then buy the 7Q [], and an Odyssey/Convergent Design branded SSD. [ for 240GB] in order to use the free DNxHD codec.
3. This part confuses me. We then have to pay another for FS700 support? Does it not record 2K raw out the box?
It is said that if you buy a Odyssey SSD, you get free Avid DNxHD recording, but the FS700 does Cinema DNG. Could someone please clarify this for me?
With all that said, does this mean that the final costs to record 2k will be:
Sony Upgrade [$ Unknown] + Odyssey 7Q [] + SSD [] + FS700 support [] which totals to ? If not, please clarify
Yash Bagwandeen is offline   Reply With Quote
Old May 10th, 2013, 01:01 AM   #2
Re: I don't understand these costs for 2K raw with the Odyssey
if you just want to record 2k with DNXHD, get a blackmagic shuttle 2, it is only 350$ and you can use regular SSD (while from a limited brand and model).
Old May 10th, 2013, 09:30 AM   #3
But then be aware you can only record at a maximum of 30 fps, so it won't be able to capture the Super Slomo of the FS700. For that you need a recording option of 60 fps.
Cees van Kempen
www.iwp-wildlife.com
Cees van Kempen is offline   Reply With Quote
Old May 14th, 2013, 04:44 AM   #4
Hi - I am Mike Wattley, Sales Manager at Symbiosis, the EMEA Distributor for Convergent Design. Basically you buy the Convergent Design Odyssey 7Q, which includes the DNxHD recording capability at no extra cost, you do need to buy an SSD to use this feature. You can then add an extra Codec, for example support for the FS700, this is done via the Convergent Design website (this can be purchased, or you can rent it on a daily basis).
The costs will be confirmed shortly, but you would need:
Odyssey 7Q
SSD(s)
FS700 Support (the Sony upgrade & FS700 support are one in the same)
Mike Wattley is offline   Reply With Quote
Old May 14th, 2013, 04:58 AM   #5
Thanks Mike. Someone told me that with a 7Q and Convergent Design SSD, you can record 2K compressed, but paying for FS700 support will get you 2K RAW
Old May 14th, 2013, 08:03 AM   #6
This model has the potential to be a PR disaster seeing how much confusion has been generated even before the first one has shipped.
I hope everyone ordering one understands what options are needed for their application and their costs to get a functional system.
I strongly recommend CD offer ONLY "Packages" based around the different cameras they will support. Selling this thing a la cart is going to be trouble.
http://www.LandYachtMedia.com
Old May 14th, 2013, 05:49 PM   #7
CD announced codec pricing today.
FS700 RAW codec: Purchase: $1495 Rental: $75/day
includes HD/2K Raw up to 240fps (.dng format) and Quad HD/4K YCC Uncompressed up to 30fps (.dpx format) for the Sony FS700 (the HXR-IF5 interface module is not required).
http://ci34.actonsoftware.com/acton/...reparedMessage
Tim Dashwood
Old May 19th, 2013, 04:51 PM   #8
Convergent Design
Hi Cees-
We upped the CODEC performance on the base model to 60fps to support super slowmo capture off the FS700. Yes, you need an extra cost recording option for 120 and 240 fps, but you can record uninterrupted with the Odyssey7Q (OK, it's limited to 30 minutes of 2K @240fps using two 960GB cards).
Mike Schell
Convergent Design
Mike Schell
Convergent Design
Mike Schell is offline   Reply With Quote
Old May 19th, 2013, 04:57 PM   #9
Convergent Design
Hi Chris-
The record options are tied (as much as possible) to specific cameras: ARRIRAW, Canon C500, FS700, 2K Raw, etc. Each CODEC package supports all the capabilities in a given camera. The C500 package includes 4K Raw (up to 60fps), 4K Half-Raw (up to 120fps), HD/2K RGB 444 10/12-bit etc. The uncompressed and quad-stream recording option are not camera specific, since they support good old 1920x1080 HD video.
Mike Schell
Convergent Design
Old May 19th, 2013, 05:07 PM   #10
Convergent Design
Hi Yash-
The Odyssey7Q ($2295) includes DNxHD up to 60fps. We're hoping to add a second popular CODEC in the near future. If you want to record 2K/4K Raw from the FS700, you need to add this recording option (via a web-based purchase) for $1495 (unrestricted license) or rent for $75 per day.
The SSD pricing is 240GB = $595, 480GB = $1195, 960GB = $2195. You will need at least two 240GB SSDs to support 2K RAW @ 240fps, which at over 700MB/sec must be stripped over two drives (RAID0).
Mike Schell
Convergent Design
Old May 20th, 2013, 01:55 PM   #11
So, to get full functionality of the device with an FS700, you'll actually need to buy TWO Convergent Design SSD drives, not just one, right?
Eric Darling is offline   Reply With Quote
Old May 20th, 2013, 01:59 PM   #12
This is exactly what I'm talking Mike Schell. It seems simpler to those on the inside. Things need to be put together as packages with EVERYTHING that is needed to get a functional system going.
Old May 20th, 2013, 02:53 PM   #13
Convergent Design
Yes, if you want to record FS700 2K RAW at 240fps (which is over 700MB/sec), then you need at least two SSDs. They can both be 240GB in size. On the other hand, you only need one SSD for 120fps.
We're putting together a comprehensive chart to show all the various configurations.
Mike Schell
Convergent Design
Old May 21st, 2013, 02:37 PM   #14
On one hand the concept is really simple, on the other hand the options make it very complicated.
Add 'fast readers' to it and it gets even worse than this...
A short video or even better: an 'explainimation' could help getting the info across to the filmmaking crowd.
If you need any help with that.... ;-)
Brainstormnavigator searching for the hole in the sky.....
Audiovisual Designer (NL) - http://www.brokxmedia.nl
Walter Brokx is offline   Reply With Quote
Old May 22nd, 2013, 08:03 PM   #15
Convergent Design
Hi Walter-
Thanks for the feedback. We are trying to rearrange the recording options based on specific cameras. So, we'll have an ARRI Alexa, Sony FS700, Sony F3, Canon C300, Canon C500,etc packages. Basically each package will enable all the functions of a given camera, to the extend they are supported by the Odyssey. For example the Canon C500 will include 4K/QHD Raw, 2K/HD RGB 444 @ 10/12-bit, etc.
Do you think this would clarify the issue?
Mike Schell
Convergent Design
