-   Convergent Design Odyssey (https://www.dvinfo.net/forum/convergent-design-odyssey/)
-   -   Multi-stream in 720? (https://www.dvinfo.net/forum/convergent-design-odyssey/524443-multi-stream-720-a.html)
Brian T. Young August 8th, 2014 01:39 PM
Greetings -
My brain may be going, but after the latest update that enabled 720 in the 7Q, i can't do multi-stream (quads) in 720/59.94 - is this correct?
Dan Keaton August 9th, 2014 10:48 AM
Re: Multi-stream in 720?
Dear Brian,
That is correct.
We have not added 720p to Multi-Stream, and 1080i is not support either.
Later we will be updating Multi-Stream to make it more inclusive.
Respectfully,
Alex Teo August 10th, 2014 04:46 AM
Hi Dan Keaton
the Next Firmware Update is it support Apple ProRes 442 and Apple ProRes 422 (LT)
for long hr REC 2Hr 30min ?
how about SD NTSC/PAL video is Supported ?
and Full HD 1080 50P and 60P Rec ?
Multi-Stream Monitoring for live multi-cam switch
need to fix!!!
able to see the Quad Split view screen by selector
A/B/C/D buttons with out change to " Full screen", why ?
not able see other camera shoot A,B,C,D
must have the Quad Split view screen
so we see other camera shoot !!!
only the SDI out is Full screen to live out for projector
possible to Rec SSD on the final mix out for live multi-cam switching ?
only the mix out to projector? not the Multi-Stream rec
Alex Teo
Dan Keaton August 10th, 2014 06:58 AM
Dear Alex,
I will answer your questions one by one for clarity.
No, sorry, that is scheduled for a later release. This is not imminent.
SD NTSC/PAL is not on our current roadmap, nor has it been promised.
We have promised this, just stay tuned for an announcement.
need to fix!!!
I understand your request, and I will discuss this with our team.
And yes, I would like for us to add the feature that you have requested.
I am sorry, but I do not understand this question. Both the HD-SDI and HDMI outputs are Full Screen or Quad Split, depending on your setup of the Odyssey7Q.
If I understand your question, you want to use Multi-Stream Recording, say with three cameras, record each camera isolated, and also record the live mix output as the fourth separate recorded video stream.
Yes, we want to support this mode, and we expect this to be part of our Multi-Stream Recording Option, which is an extra-cost option for the Odyssey7Q.
Our Multi-Stream Recording Option is not available yet, but the ability to use Multi-Stream for monitoring is available in 1080p.
I hope this helps.
Alex Teo
