Tim, thank you for the suggestions. I don't know of a way to set field dominance in FCE for AVCHD, just DV can be set to "upper field first/lower field first", no option for "none". FCE doesn't have Motion 4, the issue must be with the new QT. I am not using adobe S/W @ the moment. If you or anyone else has some suggestions, these are greatly appreciated and will be tested. The more I observe my results, the more it seems you are correct that interlacing is somehow involved. The Sony's (HDR-SR11) I am using are definitely running at 59.94i, but I don't know what to do about it. Do you have any suggestions? Should I try to de-interlace the clips before I use them in FCE? FCE seems much more stripped with respect to FCP than what I heard. If anyone has any suggestions, I'd really like to hear them. I would love to be able to generate BD's with the checkerboard pattern, to distribute as test discs, etc....
Thanks to Tim Dashwood's tireless support, I made great progress this weekend in getting beautiful 3D out of the DLP/Laser TV sets. What works: The anaglyph outputs work (the picture quality is limited by the techchnique), but the side-by side output provides much higher quality, colors, etc. so that is what I concentrated on. I still have to output h264.mov to a PC where I convert the files to WMV.wmv files to be played with Peter Wimmer's Stereoscopic Player (3dtv.at), via HDMI into the TV's. The results are great, limited by my cinematography skills, not by the technology. I would wish if I didn't have to go the PC way, but I cannot get the video out of the FCE or QT to pixel align with the TV, so I can see both images with either eye and see no stereo effect, of course. I cannot get consistent over&under scaling and the line interleaved output doesn't seem to work with Peter Wimmer's player. Tim said that he will look into FCE this month. Actually I would prefer to distribute on BD's but cannot generate discs with the pixels alligned/3D effect with neither the Toast 10 nor the Revolver. Don't exactly know why. By the time the h.264 to WMV converter deals with the stream, it is 1920x1080x29.97p, so no interlacing should be involved either. So the results are mixed at the moment, but there is a solution that works really well. Many special thanks to Tim Dashwood for his continuous help. If anyone else has a simplier solution that works, please post the details.
First try
I decided to un-post the first try of 3D anaglyph. Thank you.
I fixed up the data rates, etc. and re-posted on Vimeo: San Clemente, CA - R&C Anaglyph on Vimeo , and on YouTube: YouTube - YT NA 264 proj. The Stereo3D Toolbox did a great job for posted material. This is mainly for those interested in a bit more budget-oriented solution, such as myself. Any constructive criticism is appreciated. Thank you.
Only red in anaglyph?
Hi Tim,
I'm trying out the plugin with FCP7.0. I have two nested sequences on a new timeline. Applied the plugin to sequence 1 and chose sequence 2 as right image. If I choose side by side as the output mode, I get perfect 2:1 squeezed side by side. If I choose any of the anaglyph modes I only get the left eye showing! (i.e, just a red image) I've tried other clips, restarting, and adding/removing the plugin but cannot get anaglyph to work! This is in snow leopard. On another matter, can any users recommend a dlp TV around the £1500 mark that will accept checkerboard from FCP? It seems there is a lot of choice in the US, but for some reason whenever I think I've found a suitable model in the UK it ends up as 'discontinued'. |
Simon. Can you please zip and email me your FCP project file? I can probably better understand exactly what's going on if I can see how you have it all set up.
This is the first I've heard of this sort of issue. As for the TV question...you should look for any DLP that has the 3-pin 3D sync output on the back and has a native resolution of 1920x1080. I just picked up a Samsung Plasma PN50B450 for $900 at Best Buy, but it's resolution is 1360x768 so it isn't working perfectly with the plugin with sources at a higher resolution. The A450 and B450 series Plasmas (not LCD) support checkerboard input. The B450 seems to also accept interlaced input. 720p source material is great but 1080p is cropped. I'm working on a solution for this particular model. |
thanks Tim
Thanks Tim, I've sent the fcp file to your dvinfo email.
I just ordered a Zalman 22. It seems other people have this model working fine as a preview monitor! Are either of those plasmas you mention polarized, or do they use the shutter glasses? I was working for a film company recently and they said the glasses eat batteries like...something that uses a lot of batteries. Also they were quite bulky! Am I right in thinking you get a darker image from shutters? I'm after a large screen passive system! I wonder if anyone makes a revolving polarizing filter to put in front of a standard DLP projector? |
Zalman Trimon 22" not working with 2009 macbook pro
Strange. I've read other people having success with this monitor, but my MBP doesn't even recognise that a display is attached. Weird thing is, my old powerbook works fine (but isn't fast enough to run FCP in HD)
Anyone else using external monitors for 3D with a MBP? |
Stereo 3d Toolbox for Win OS
I'm loading FCP to test your plug in. My associate editor works with After Effects in the Windows platform. Could you tell me if the demo version is available for him to trial on that Win OS yet? If not, when do you suspect it will be? Cheers, Christo |
| All times are GMT -6. The time now is 01:43 PM. |
