-   Digital Compositing and Effects (https://www.dvinfo.net/forum/digital-compositing-effects/)
-   -   Motion Tracking different objects in one pan shot? (https://www.dvinfo.net/forum/digital-compositing-effects/108076-motion-tracking-different-objects-one-pan-shot.html)
David Green November 15th, 2007 07:49 PM
Hi,
I'm trying to motion track a handheld shot that pans from the interior of a car door up and out of the window to a blank sky.
The only problem is, once the camera tilts up beyond the interior of the car door, there is momentarily nothing for the motion trackers to grab onto. A second tracking anchor appears later in the shot - but only after a considerable delay.
My question is this:
- Is there a way to use a tracking point for the beginning of a shot, use no tracking points for the middle of a shot, and use a 2nd, new tracking tracking point for the end of a shot?
I'm using AE CS3.
Many thanks!
Dave
Ray Bell November 15th, 2007 09:48 PM
This should help you out... I think the method is called rotoscoping...
http://library.creativecow.net/artic..._pete/roto.php
David Green November 19th, 2007 05:36 PM
Thanks for your help!
Actually, this is the tutorial that helps the most:
http://library.creativecow.net/artic...extensions.htm
