-   Digital Compositing and Effects (https://www.dvinfo.net/forum/digital-compositing-effects/)
-   -   Slideshow with artifacts (https://www.dvinfo.net/forum/digital-compositing-effects/110065-slideshow-artifacts.html)
Chad Solo December 12th, 2007 12:55 PM
Ok hope I can explain this right. I did a slide show in Vegas and it's about 10 minutes with Pan and zoom and transitions I rendered it out to a uncompress AVI and when I watch it all looks great. Then I imported in After Effects and added this 3D fly through and some music so when I rendered it out either Uncompress or Mpeg I get these artifacts around the face and other parts on the slideshow when its panning. It looks like the face and other parts of the photo is kinda moving . My template is DV Widescreen Bottom Field I used that setting for the slide show and then in after effects. If anyone has any suggestions I would appreciate it.
Thank's
Ray Bell December 12th, 2007 02:04 PM
you might try to switch to 32bit... ???
Chad Solo December 12th, 2007 04:33 PM
Thank's for the reply I tried that and still the same. What I ended up doing was opening it up in Premire pro and rendering it out from there and it looks good. I just would like to know why After Effects is acting like this.
Thank's
Chet
