-   Digital Compositing and Effects (https://www.dvinfo.net/forum/digital-compositing-effects/)
-   -   Problem with artifacts/grain (https://www.dvinfo.net/forum/digital-compositing-effects/234064-problem-artifacts-grain.html)
Aric Mannion April 26th, 2009 08:06 AM
I had a shoot in very low light that I've fixed with levels in after effects. It looks good, but the levels brought up a lot of grain and artifacts. Has anyone successfully limited the amount of grain or artifacts from darker areas in after effects? The footage is HDV (now pro res) so this was to be expected.
Christopher Glavan April 26th, 2009 04:20 PM
My first wedding gig I had the same issue- delays made for a very ark outdoor reception, and I was forced to gain up my cam. Unfortunately, there's only so much you can do with grainy/artifacty footage. If there's any way you can go back and re-shoot definitely do it. If not, I'd maybe spend a little extra time color grading- I was able to tweak a bit in Color (mac), then go back to AE and re-adjust the levels a bit and bring the artifacts down- but it didn't make much of a difference.
HTH!
Bob Hart April 26th, 2009 08:28 PM
Quick and dirty assist.
If you can live with a smear or light-trail effect, try putting indentical clips on three video tracks. Make the upper two tracks about 33% opacity. Slip the upper or third track two frames late and the middle or second track one frame late. Mute out or delete the sound tracks of these two clips.
Render out or export the layered vision.
You may have to bring up contrast as layerstacking will have the effect of reducing it.
Oren Arieli April 26th, 2009 10:57 PM
Get yourself Neat Video's noise reduction plug-in for Adobe (PC, with Mac version released soon). Neat Video - best noise reduction for digital video
Slow to render on HDV...but results are amazing.
Christopher Glavan April 27th, 2009 04:37 AM
Didn't know about either of those. Always nice to learn something new from the crew here. Thank you guys!
Aric Mannion April 27th, 2009 10:29 AM
I've been experimenting with the noise reduction effect in After Effects and it's not bad. It's trial and error with insane render time, so any tips on that would be helpful.
There are a couple of shots that I actually wanted a bit of a smear added, so I think I will try this suggestion too. I can't imagine how it would help fix grain, but I'll take a look.
Laurence Scott May 1st, 2009 05:17 AM
I was going to suggest the same thing
Jonathan Massey May 24th, 2009 03:07 PM
Just giving my thumbs up for Neat Video. I have the mac version.... the best grain eliminator for digital video!
