Re: MoVI BTS Stabiliser Rig
It takes multiple people now, but imagine integrating something like this with in-camera face and scene/composition detection. You could then walk through a shot ahead of time and set keyframes that would execute the appropriate focus and framing automatically while you operated the rig.
Regarding framing: again, if one is shooting a simple subject and the goal is a mechanical result such as "glue them to the crosshairs" or "glue them x amount to the left of the crosshairs", possibly this would work. Even still, what is "proper" headroom for every variation of distance to the subject? I constantly ask my operators to make minute adjustments to headroom to fit my aesthetic (after having spent a good number of years having that inflicted on me). It's a little bit like asking a computer to make a painting. Every nuance of framing, especially with a moving camera, is very much a part of the operator's skill, artistry and even personal expression, if I may use such a flowery term. Watch this exquisite shot from the legendary Steadicam operator Larry McConkey, and pay very close attention to where he places Pacino in the 2:40 frame at any given moment. It's like a masterclass in framing. None of it is left up to chance, every moment is a choice made in advance and executed flawlessly, reacting to the nuance of performance with the speed of light. No piece of software is going to duplicate that. I can't begin to compare myself to Larry but he was my greatest influence as an operator and I certainly bore his lessons in mind when I designed this little number (that link includes breakdown of the shot design, but the video quality is pretty awful--this is marginally better). As far as the Movi itself as a possible Steadicam replacement--it's an evolutionary step, and not unexpected. We are sure to see this technology merge with Steadicam (I well expect to see it mounted to a Steadicam arm soon enough, which will aid with both the weight management and vertical stability) and make its way into many other scenarios other than a handheld stabilizer. I personally expect to see axial stabilization happen on in-camera within a few years, making external apparati like these unnecessary. But this is a step along the way. |
I think it has some very interesting possibilities.
Will we see longer, freemoving shots show up more now in corporate videos, indiefilms and commercials? |
Fwiw...
It's a great item. However.. I saw 2 other s just like (granted lighter and unfinished) that will be around $2k. Id expect within 18 months there will be multiple options under $3k for DSLR cameras. Will have pics wheni get out of this Tijuana jail and back to the USA. Dvinfo bail posting is slow. |
Here's the quick video we did yesterday at the show......
Jim Martin Filmtools.com |
Evan:
Not quite sure I understand the distinction you are making, but it's cool, the future will bring what it brings. Focus is a better fit for an automated process than framing, in any event. A large percentage of the job of focus pulling is keeping a specific subject sharp, with a small percentage devoted to making choices on what that actually means and transition focus to other subjects. So, that could more likely be automated via face recognition. I've imagined for a few years now a tablet setup where an AC would tap on the desired subject, swipe to the next subject to do a rack etc. The best use of framing assist is to eliminate backpanning due to rotation of the chassis, such as transitioning out of a curve into a straight section, or panning a jib while attempting to maintain a straight-ahead orientation. Stabilized heads do this by nature and it makes it easier for the operator not to have to dial in a pan to keep the lens looking the same direction. I'm a little perplexed by some of the suggestions that are being bandied around that you don't need much "skill" on the side of the chap carrying the Movi, that a PA can be just tossed the rig and away you go. Placing a camera into space is very much part of the process of making a moving shot successful. There are a significant number of decisions to make at any time: what height should the lens be, what speed and acceleration of movement in the three lateral axes is ideal. I had many experiences operating remotely while relying on others for the placement in space of the camera (Skycam, dolly, Technocrane) and it can be either exhilarating when you have that innate communication, or eminently frustrating when you don't (you find yourself straining at the controls muttering "come on! move!"). One of the things that makes Steadicam so satisfying is that you can regulate all axes of movement yourself, which allow for incredible subtlety and the ability to react at the drop of a dime. Very much trickier with a two-man band. |
Charles,
For the last 9 years we have been operating cameras remotely on RC helicopters and I have the same thoughts as you. I have been working with the same camera op all that time and we have found that when we are allowed to "do our own thing" really good things often result. We have gotten pretty good at anticipating one another. This didn't happen over night. Even now we occasionally get out of sync at times. When we get micro-managed and/or thrown off of our normal flow, usually by outside influences, it gets frustrating very quickly for everyone. I am looking forward to getting this thing to see for myself. I don't think it is going to make any of what I mentioned any easier, but the final result will be far more stable. |
Hello,
we plan to offer our handheld brushless stabilizers soon. There will be a version for cameras around 2 kg, one for cameras up to 5 kg, like the Red Epic and we also build a stabilized head for cameras up to 10 kg, to be used on a steadicam arm or easyrig. The mid sized version is the most advanced in the moment. This is a test with 5 kg weight including camera and brass weights: We have first prototypes to test and improve step by step and plan to add small joysticks to the handles for better control of pan and tilt in single operator mode. For more information, upgrades and new videos you might visit our website www.portahead.de from time to time. Andreas Kielb |
When I said months... I really meant WEEKS. :)
Here's a new one called a DEFY in three versions, they said would be $1800.00, but now I see you can order the 2 lb one for $2,300.
DEFY PRODUCTS by RELENTLESS, INC. Cheers, Vaughan |
Within a year I imagine there will be as many as a dozen gimbals on the market (i.e. actually shipping), all doing roughly the same thing. And probably 18 months later, half of them will be out of business as they deal with supply and demand issues, component availability, fierce competition etc. Keep that in mind when you make your purchase, peeps. Early adopters face the the very real possibility of an unsupported purchase.
I dread this scenario. If something fails either due to design or component quality, routine wear and tear or simply operator error, these rigs can be costly paper weights.
Better to wait till next year for this category to mature a bit. Quote:
| All times are GMT -6. The time now is 12:01 AM. |
