Sony PS3 now supports AVCHD
Sony has released verson 1.90 for the Playstation...
supports playback of AVCHD, up conversion of Audio playback and supports Blu-ray output of 1080 24P among other updates included......... |
playing back 1080 thru a PS3
Has anyone been able to output 1080 (i or 24p) material from their computer via ethernet to a PS3's HDMI output and onto a HD ready LC TV?
I can render HDV 1080/60i files from my editing timeline to a USB2 hard drive and use that to stream video from the PS3 to a 1080p LCD display. This looks great and is much easier than trying to burn a DVD (either SD or HD).
Kevin, what settings are you using for rendering to 1080/601?
I'm using the "Speed Encoder" option in Edius which lists the following defaults for 1080i output:
Video: 1440x1080, 29.97 fps, Video Aspect 16x9, MP@H14, 25.0 Mbps VBV, Buffer Size 896 KB Audio: 48.0 Khz, 16bits, 2ch, 384kbps Hope that helps... |
Thanks Kevin for your input. I quoted you in another thread "Non-Linear Editing on the Mac"
How do you get past the file size limitation in your USB2 Hard drive, or are your files smaller than 4 GB? thanks |
As far as I know that's correct: the PS3 only recognizes FAT32 partitions and hence file sizes under 4GB. That's still about 20 minutes of HDV material at 1080i or a little more at 720p.
I tried a myriad of different settings recently exporting an H.264 file from Adobe Premiere Pro CS3 for playback on a PS3 and everything came up as corrupted data.
I tried a bunch of 1280x720p settings, and a bunch of 1440x1080p settings (i.e. main profile, high profile, different levels, etc.) I tried copying from a memory stick, and also by streaming with Red Kawa's server, but it always came up as corrupted data. The one thing I didn't try was changing the frame rate. I wanted to keep it at 23.976p but I figure I'll try 29.976p tonight and see if that fixes things. Otherwise.... back to MPEG-2. |
Possible Mac Blu-ray authoring work-around
Apparently people have been able to burn 1920x1080 clips on a regular DVD on a MAC that will play back in a PS3.
Having said ths, I still don't understand why it's taking so long to a FCP compatible Blu-ray authoring solution... |
1.92 released today
http://www.us.playstation.com/ps3/ne...304&LINK=PS3SU Quote:
2.0 to be released very soon.
http://blog.us.playstation.com/2007/...e-update-v200/
http://blog.us.playstation.com/2007/...demonstration/ -EDIT- They finally got the 2.0 firmware page up. http://www.us.playstation.com/PS3/Ne...s/default.html |
Firmware Update 2.01 released.
http://blog.us.playstation.com/2007/...e-update-v201/ |
I can't get my PS3 to play back anything rendered out of PPro CS3 - neigher MPE2, nor AVC (H.264). The HDV MPEG2 was playing before; I will try older HDV clips captured and rendered out with PPro CS2. I am wondering if I should blame PS3 firmware 2.01 instead of CS3...
Hmmm. I haven't had any issues w/ firmware 2.01
All the HDV and MPEG-2 exports I've stored on the PS3 hard drive are still playing back fine. It's only H.264 that I couldn't get to work properly, but I haven't tried it lately. |
More info on playing m2t files etc. on PS3
Putting a link in this thread to another with similar information that might help someone below.
http://www.dvinfo.net/conf/showthread.php?t=108564 |
| All times are GMT -6. The time now is 12:54 PM. |
