Unable to transcode above 20Mbps?
I have a .mov MPEG-4 at 393Mbps. I want to transcode it to a .mp4 h.264 at 30Mbps, but the highest I can get is around 20Mbps. I have tried VBR and CBR, and I've even cranked the bit rate slider up over 100Mbps. I have tried using Adobe Media Encoder and MPEG Streamclip. Can someone explain this?
Re: Unable to transcode above 20Mbps?
You have cranked the slider up to 100Mbps? Then how do you know it's not going over 20Mbps if you can move the bitrate slider well past that point?
Brad,
Brad are you maybe confusing file size with encode bit rate? In other word is your original .mov MPEG-4 file encoded at 393Mbps or is it 393 MB in size? The original may be encoded at a bitrate lower than what you are choosing to re-encode it at. |
Format : MPEG-4 Format profile : QuickTime Codec ID : qt File size : 2.76 GiB Duration : 1mn 0s Overall bit rate mode : Variable Overall bit rate : 393 Mbps Encoded date : UTC 2017-04-13 20:53:04 Tagged date : UTC 2017-04-13 21:03:28 Writing library : Apple QuickTime ©TIM : 00;00;00;00 ©TSC : 2997 ©TSZ : 100 Video ID : 1 Format : RLE Format/Info : Run-length encoding Codec ID : rle Duration : 1mn 0s Bit rate mode : Variable Bit rate : 391 Mbps Width : 1 080 pixels Height : 1 080 pixels Display aspect ratio : 1.000 Frame rate mode : Constant Frame rate : 29.970 fps Color space : RGB Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 11.199 Stream size : 2.74 GiB (100%) Language : English Encoded date : UTC 2017-04-13 20:53:04 Tagged date : UTC 2017-04-13 20:53:04 Audio ID : 2 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : sowt Duration : 1mn 0s Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 11.0 MiB (0%) Language : English Encoded date : UTC 2017-04-13 20:53:04 Tagged date : UTC 2017-04-13 20:53:04 Other ID : 3 Type : Time code Format : QuickTime TC Duration : 1mn 0s Time code of first frame : 00:00:00;00 Time code, striped : Yes Language : English Encoded date : UTC 2017-04-13 20:53:04 Tagged date : UTC 2017-04-13 20:53:04 |
There are a few possibilities. Support for atypical aspect ratios can be spotty. A QT MOV/mpeg-4 has its own format limitations, which may have been exceeded with a previous encoder (it may not be a QT-legal file). I don't know much about MPEG Streamclip, but, AME is a bit limited on some of these things.
Before getting into deep testing on any of the above, I'd try Handbrake. It's freeware, and is built on the truly excellent x264 encoder. Typical results would be better than AME. Note also that setting profile and level on any h.264 encoder can limit max bitrate. Here's a chart. Most encoders will respect the allowable bitrate for a particular profile and level. In some encoders profile and level settings may not be clear. |
Echo what Seth said.
1. Handbrake 2. Your goal is good looking video at a reasonable file size. Take a short segment and encode at different bit rates, you might be surprised higher bit rate might not look better. I also caution you about going overboard with highest bitrate. It might not play on a clients device/computer. Bigger isn't always better. |
We are able to use FFmpeg directly to achieve 30Mbps, but we want a GUI that anyone can use. |
Another possibility is that the encoder has run out of video image detail that it requires data for the encoding of. Being a well behaved encoder, it would therefor only use as much data in the finished file as it actually required (still essentially working within the data rate ceiling) and not any filler data.
Andrew |
| All times are GMT -6. The time now is 06:08 AM. |
