-   Dolly / Track / Cable (https://www.dvinfo.net/forum/dolly-track-cable/)
-   -   slow crawl with a dolly (https://www.dvinfo.net/forum/dolly-track-cable/68781-slow-crawl-dolly.html)
Bryan Aycock June 3rd, 2006 10:18 AM
I heard many mention trying to acheive a slow crawl with a dolly, and some people talked about hooking up some sort of slow turing motor to do this smoothly. Well, I have an idea and want to hear what you all think. What if you mounted a fishing reel (just the reel) to a 2 foot long 1"X6" board, stood on each end of it with the reel between your feet, and literally reeled the dolly towards you. With some heavy fishing line and a low gear ratio reel, you could keep the speed consistant. What do you all think?
Marcus Marchesseault June 3rd, 2006 05:27 PM
That sounds like a reel great idea!
Dean Sensui June 3rd, 2006 05:39 PM
Fishing reels usually have a rather fast retrieve: They're geared that way to get the line in quickly. Some have two speed settings to deal with heavy loads (something we all wish for) or for a fast retrieve in case the fish makes a run toward the boat.
If you want to use a motor, there are geared low-speed motors that run film processors, etc, which might be available at surplus outlets. There was a place here in Honolulu that sold stuff like that but they went out of business.
Or you might want to create a simple hand-cranked, spool-type device. Use a long handle with a small spool and you'll get a slow retrieve.
Bryan Aycock June 3rd, 2006 09:54 PM
Yeah
Yeah after I posted this, I played with some of my fishing reels, and they are kind of fast at the retrieve. That's when, like you said, I realized some type of big handle/little spool type device would work best. I just figured it would be a lot cheaper than a motor, and its speed could be variable as well.
Greg Boston June 3rd, 2006 10:46 PM
How about a boat trailer winch. They have a nice thick strap, and a low gear ratio. Just need to hold or remove the ratchet mechanism.
Just something to think about.
-gb-
Jon Fairhurst June 4th, 2006 12:50 AM
Or a garage door opener. You can even operate it with a remote control. :)
Phil Bloom May 8th, 2008 04:55 PM
reviving this as I want to do this so i can do timelapse dolly shots...
Chris Li May 8th, 2008 06:16 PM
something like this ?
http://www.trevswork.com/mo/
Mark Wisniowski May 11th, 2008 09:32 PM
You can use a motor from a rotating disco ball. You can find them here: http://www.sciplus.com/singleItem.cfm/terms/12254
5 rpm and runs between 6-12 V DC, (very easy to keep it portable). You can attach a larger pulley wheel to the motor to collect the string attached to your dolly.
Chris Soucy May 11th, 2008 11:31 PM
Even better...........
And with a bit of luck, even free!
A surplus/ trashed battery powered drill. See 'em turfed out every day (usually 'cos the NiCad's have died).
The motors/ gearboxes have more grunt than you'd give them credit for and have speed control built in, the chuck allows you to afix just about any type of spindle/ reel system you can devise and most will work off a 12 volt lead acid battery no matter what their stated voltages are.
Worth a try.
CS
Phil Bloom May 12th, 2008 02:53 PM
it needs to be REALLY slow though
Bob Woodhead May 28th, 2008 11:37 AM
Make it a union job? ;)
Onno Perdijk May 28th, 2008 02:37 PM
Hello Philip,
How slow is slow?
1 meter/second? 10 cm/second? 1cm/second?
Slow speeds does not necessarily mean small motor... For a decent move with no vibrations you will need a strong motor with a big rotation-reducer. In combination with a small pulley you have the power and reduce the speed.
A slow rotating motor will always have its vibrations: So you will need to let your motor run at max speed and reduce speed with gearboxes and pulleys..
A source could be an electrical step?
Onno Perdijk
Key Grip / Manufacturer
Netherlands
www.solidgripsystems.eu
Onno Perdijk May 28th, 2008 02:42 PM
btw:
a 2000 rpm motor with a 1/30 reductor and a pulley of 6cm will give you a max speed of 21 cm/second....
This combi can pull a 50kg straight-line. So the dolly-weight on smooth running track can be over 200kg... (just finished math-school, :-) )
Onno
Phil Bloom May 28th, 2008 02:45 PM
can you make me one?
Onno Perdijk May 29th, 2008 03:43 AM
Hello Philip,
No problem, I can make you one. Does 21cm/second sounds good to you? Or do you want to go less speed?
What others specs do you have? Track gauge, Height of the pulley?
pricing is 900 till 1500 depending your demands and how much DIY you want to do.
Please call me: +31653201455
Best regards,
Onno
Onno Perdijk
Netherlands
Chris Swanberg January 12th, 2009 08:34 PM
Chris Li..... that was way cool..... thanks for posting that.
Vegard Paulsen March 23rd, 2009 06:04 AM
Test number 1
YouTube - First test with DIY dolly and slow motor
test number 2
YouTube - Sunset timelapse test - with moving diy dolly
Here is a DIY slow torque motor dolly i did..
At the end of the first video you can se some stills of the motor i used.
Its a regular 230v mirrorball motor. it moves at about 12cm pr min.
to slow it down to 6cm pr minute i did a pulley system with two strings.
David W. Jones March 23rd, 2009 06:37 AM
You might try here for motor ideas.
https://bmumford.securewebsites.com/...ary/index.html
Rotary Table Controller
Good Luck with your project!
