-   DVD Authoring (https://www.dvinfo.net/forum/dvd-authoring/)
-   -   Print own DVD labels or outsource? (https://www.dvinfo.net/forum/dvd-authoring/112897-print-own-dvd-labels-outsource.html)
Aron Yert January 22nd, 2008 10:40 AM
What is the best method for printing your own DVD labels? Which brand?
I'm only doing a handful of these right now (literally less than five), so I'm not sure how much I would want to invest in expensive equipment that I would rarely use. Are there consumer brands available that are somewhat affordable but halfway professional?
I would not mind outsourcing this to a company that has the equipment to do it professionally, but I would think I'd need to produce 100 or more DVDs for it to be affordable per disc, right (which I'm not)?
Any suggestions?
Ger Griffin January 22nd, 2008 10:49 AM
when you say labels do you mean for the dvd surface itself or
the inlet for the cover?
either way a lot of the new injets are very good at these tasks.
there are inkjet printable blank dvds that some printers can print directly onto.
the quality is surpirisingly good.
as for inlets, usually the paper quality plays a major part in the final look.
epsons printers are good. I use the r200.
Jeffrey Lovell January 22nd, 2008 10:56 AM
I would say that for runs up to maybe 75 it would be far cheaper for you to just by an Epson R260 or similar and printable media. I do this for my business and really like th lok of the matte finish. Cost of the DVD-R's I use are $0.42 and new set of ink cartridges run about $75 at Sams club but are good for around 100 discs depending on ink usage. I figure my cost for everything to burn and print 1 DVD is about $1.50.
Jeff
Harm Millaard January 22nd, 2008 10:59 AM
Never use labels. The heat in the DVD player will soften the glue, the spinning speed will cause slight displacement of the label and that will cause instability, thereby reducing play back compatibility.
Only use printable DVD's and an inkjet printer like the Canon Pixma series. The Epsons can not measure up to the Canon for printable disks.
Terence Murphy January 22nd, 2008 11:39 AM
Be aware that because of patents controlled by Epson, the Canon Pixma printers will not print on DVDs in the US out-of-the-box. Its supposedly possible to buy a CD/DVD tray off e-bay and download different drivers to make the US version print to DVDs, but I know my dad wasn't able to make it work with his Canon.
I'm pretty pleased with my Epson R260, although we're having DVD tray feed problems again. See http://dvinfo.net/conf/showthread.php?t=86500 for more details.
-Terence
Jacob Burson January 22nd, 2008 01:58 PM
DVD labels or case insert?
I use my Epson R220 for DVD labels. Never use sticker labels. Print on inkjet printable DVD media. I've had great results with Verbatim inkjet printable DVD-R disks. Typically, it takes 1 decent job to pay for the printer as you can get the R280? for less than $100 and around $70 after rebate.
One thing with anything inkjet is that there is no coating on the label. I have outsourced disks before to diskmakers for disk labels that had a protective coating sprayed on them. If you were to ever do several jobs that needed many, many disks, it might make sense to spend several hundred $$ on disk printing equipment, but outsourcing that work would save time, which has a price as well.
As for case inserts, I design my artwork and get copies printed on 32 lb glossy paper at an Office Depot or Staples at about $.69 each. Saves wear on my printer, much quicker, and a better finish. No matter what they say, inkjet prints will run if they get wet.
Trust us, you don't want to use a sticker label. They may play fine at first, but it isn't long before the disk will skip due to imbalance from adhesive breakdown.
Any suggestions?
Allen Plowman January 22nd, 2008 02:41 PM
Originally Posted by Jacob Burson (Post 812415)
One thing with anything inkjet is that there is no coating on the label. I have outsorced disks before to diskmakers for disk labels that had a protective coating sprayed on them.
I also use an epson printer, I find the print to be extremely durable. how much better is the clear coat?
Tripp Woelfel January 23rd, 2008 06:29 PM
I'll also vote for the Epson printers. I've had two an old 320 and a new 595. The new one's great. It's a subjective comparison, but I think the print quality is better. It's definitely faster and was almost free when I bought it last month. $125 at Big Box store.
Tom Roper January 24th, 2008 08:18 PM
Will the ink smear?
Allen Plowman January 24th, 2008 08:57 PM
Originally Posted by Tom Roper (Post 813840)
Will the ink smear?
I have never had the ink smear. once its dry, I can not scratch it with a fingernail. I print one, and place it on the spindle. the only thing that concerns me is sticking together. I usually print at least a hundred at a time, and I put them on the spindle as they are done. I have gotten in the habit of printing them first, and letting them sit a while before I burn them, so if the ink sticks to the opposing discs surface, then the burner will not burn it, and I will find the problem. I have never actually had this as a problem, only a fear. I have sold around a thousand discs, and no returns yet. my customers primarily use lower quality equipment, if that matters.
Pat Reddy January 27th, 2008 12:44 AM
I bought an Epson 280 last week ($80). I tried burning to and printing on printable Maxell DVD +R discs. The printed image was a bit flat on these, and I could never get the DVD +Rs to play correctly in my 3-year old DVD player.
I bought 50 Taiyo Yuden Watershield DVD -R discs yesterday at a local shop (about $38). They have a very nice glossy surface and are hub printable. The contrast and saturation are excellent, and I like the glossy surface. They are supposed to be water proof. I found no smearing of the ink even after only a few minutes of dry time. Burned at 6x, the Taiyos seem to work fine on my player.
Pat
Damon Gaskin January 27th, 2008 08:16 AM
Hi guys, I also strongly vote for the Epsons. I have had my R200 since they first came out and love it to death. I use the Verbatim +R printables, and as another poster stated, once they dry, you can run a fingernail across them without much issue. I have sprayed on some scrapbooking fixatif by 3m which works well as a clearcoat and giving a slightly matte finish. But in general I have had no issues whatsoever.
For small runs, I am not sure how the "big boys" do it, but I know that one I recieve brochures from and have order cases, advertises the Epson setups and also the Primera setups which makes me think they may possibly use them also. But you will find great results with the Epson I believe if you try it.
One thing I use and highly recommend to anyone once their warranty is up is to convert these babies to CIS(continuous ink system). The one I have, the quality is just as good, if not better once calibrated correctly as the stock Epson cartridges and it takes your printing/ink cost to laser levels if not lower(I have been running my CIS since the beginning of September and haven't gone through 1/2 of my ink tanks yet, and I print not only discs, but many documents now also) once you factor in you can buy 4oz bottles of the complete set for these printers for 35.00. The intial installis the only thing you have to take yoru time on, but once installed, they run like a charm, you don't have to worry about ink, and the quality is good(and adding additional ink is extremely simplistic to say the least)..
However, the Epson in its stock config is good also, you just have to pay the higher cost for your ink replenishment...
Mark Holland January 28th, 2008 11:25 AM
Just to add my opinion...
I no longer use labels on DVD's OR CD's for all the reasons stated above, plus, I think that discs printed directly look much better than labels.
As for the printer, I've been using an Epson R200 almost since they first came out. One of the minor problems I've had is slipping on the feed tray. I overcame that by CAREFULLY AND LIGHTLY pushing the tray as it feeds. However, I've read here (search for it) that there's a better 'fix' for that problem. (I'll get to it one day!) The other 'problem' isn't really a problem, just maintenance that needs to be performed every now and then. The rollers, head cleaning sponge, etc, need to be cleaned to get rid of the smearing problems that crop up after a few thousand cycles of discs, inserts, liner notes, invoices, and other business printing. (I know, I need to use another printer for everything else; I've recently started doing so.)
Mark
Michael Nistler January 29th, 2008 12:47 PM
-Terence
Hi all,
Terry's correct that due to patent issues, the Pixma requires DVD tray enabling (through the front panel buttons) for units purchased in the United States. Many of us have had success performing the simple setting change and purchasing the DVD tray on ebay. Just be sure to purchase the appropriate tray for your model of Pixma.
I'd never sell DVDs with sticky labels, worrying they'd get hot and fly off in the customer's computer. I highly recommend the best - the Taiyo Yuden watershield. If factors like having the lowest dropouts, best media longevity, and fantastic visual appearance that's truly durable are important to you and your clients, check it out.
Good luck, Michael
Dana Salsbury August 29th, 2008 05:30 PM
Keep in mind that the Epson printers will print random streaks now and then, so you will probably have a fair amount of coasters. Now that I'm burning Blu-Ray I'm freaked out about this, and am changing my artwork to very high-key stuff to baby the process.
Pete Cofrancesco August 29th, 2008 10:05 PM
I've had good luck with my Epson R200, 500+ dvds without a problem. I out source when I need more than 50. I've always wanted one of those automated machines that can print and burn, but I can't swallow the $1,500+ cost.
Bruce Foreman August 31st, 2008 01:40 PM
I have an HP C5230 All-in-One printer/copier/disk printer that handles my needs. Prints disks fed in singly at about 1 minute or so each and they look great.
I rarely need to do more than 4 or 5 at a time.
I also have an external LightScribe drive and that looks good as a monotone way to do it. Takes 22 or so minutes per copy but on occasion I do it that way.
My primary need is for DVD's from material I produce as a reference for the Defensive Handgun training I conduct.
Tripp Woelfel August 31st, 2008 06:22 PM
Can't speak to the Canon printers as I've never seen one print on optical media. I've had two Epson printers that would print directly on media. Can't remember the model number on the old one but the new one is a 595. Great quality but the images are a little flat on the Verbatim.
To the person who has occasional streaks with the Epson, that's a problem with your unit. You've probably got a leak somewhere inside. You can try and fix it or just get a new one. If it's still under warranty, send it back. Life's too short to endure defective gear. It'll just make you crazy.
If a new 200 costs about $80, if you ruin four BD disks with streaks, you've just paid for the printer in coasters.
Josh Chesarek September 1st, 2008 07:27 AM
If you have issues with smearing or want a glossy look, check out the Water Shield DVDs. I use those with great success :)
Dana Salsbury September 1st, 2008 10:47 AM
Good point. I shook the cartridges individually, and it has worked fine since.
BTW, Lightscribe DVDs flake out over time. My archived Lightscribes are a mess.
Dana Salsbury October 1st, 2008 07:23 PM
Laserjet that prints onto DVDs?
After burning a few more, we're back to fading in/fading out. I'm freaked out at the thought of printing Blu-Ray. This is the most inconsistant printer that I've ever had.
Is there a laserjet that prints onto DVDs? I don't care if it's black and white. No more coasters!
