-   DVD Authoring (https://www.dvinfo.net/forum/dvd-authoring/)
-   -   I heard this about DVD's.... (https://www.dvinfo.net/forum/dvd-authoring/25411-i-heard-about-dvds.html)
Dan Euritt May 14th, 2004 08:04 PM
i think that what we have here is a failure to communicate, lol!
the ONLY thing people who use recordable dvd's need to know is that the "Region Code Mask is flagged as 0 in the VMG(Video Manager)."
PERIOD... you are now fully dvd-spec legal, per the link i posted... STOP RIGHT THERE :-)
my beef with you, jake, was when you made the following bogus statement:
>>>There is region coding on every disc. You just have to flag the regions you want to be able to see the disc or not.<<<
with recordable dvd's, do NOT ever "flag the regions you want to be able to see the disc or not." ...of course you would have changed the region code mask along with that, so you would have created a dvd that is not fully legal... as was clearly explained in the link i posted.
therefore, since you cannot legally change the region code mask when using recordable dvd's, REGION CODES DON'T APPLY TO RECORDABLE DVD'S.
that is also clearly explained in the dvd demystified faq: http://www.dvddemystified.com/dvdfaq.html#1.10
on a lighter note... there are signs my re-authored dvd is now working on one of the players it gagged on before... i used reeldvd instead of the first pro version of dvd-lab, same media and mpeg2/ac-3, except that i had to re-size the 704x480 clip to 720x480, because reeldvd can't handle different sized media.
704x480 frame size is of course dvd-legal, so i think that it's an issue with the dvd-lab muxer(??)... because the dvd-lab authored version was skipping some frames even on the 720x480 segments.
Jake Russell May 15th, 2004 05:17 AM
Yep I agree with you. BUT there are MANY MANY MANY MANY dvd apps that don't have the RCM set to '0' in the VMG and that is why I brought the point up. Even if authors think they are doing things right they might not be unless they have TFDVDEdit or IFOEdit to check and change things. MANY apps set the RCM to '192' and not '0' and others flag it differently depending where you build to.
My point with this quote:
is that even if you don't want region coding on the disc or your app doesn't have the ability to change the region settings a value will be in the RCM. Even if it's '0'. So it is region coded just set to ALL or RCM '0'. That field is never blank it's always got a number even if it's zero.
BUT as you and I agree :-), LEGALLY on dvd-r it has to be '0' which is sometimes where compatibility issues come in cause apps are doing inconsistent things behind the scenes.
-Jake
