I wonder if you bought a Firestore (or other product that used SATA as the drive) If you could open it and just replace the hard drive with a solid state sata like this one.
http://www.tomshardware.com/2008/03/..._write_speeds/ |
FireStores use IDE drives. You should be able to pretty easily modify them to use a CF card, using something like this:
http://www.acscontrol.com/Index_ACS....CF_Adapter.htm Something like that would suck a lot less juice than a hard drive too. |
| All times are GMT -6. The time now is 10:21 AM. |
