Re: DVD Quality
Glad to be of help! I only use Compressor when I'm converting an export from FCPX to h.264 to upload to YouTube or Vimeo.
Re: DVD Quality
I guess the default for a Master File is a QuickTime format. P.S. David: Thans for the reply and feedback. |
Re: DVD Quality
The way I understand it, if your timeline is linked to Proxy files (which are reduced in size and resolution from the original media) then X will use those as the sources when you Share your work.
Obviously, if you're just doing email client updates or are looking for iPhone or iPad size versions, Proxy files are great, so there's no reason to up-rez before you Share. But if you're looking to final master for high rez, it just makes sense to have your project use the highest quality source files. So switching the links to the Original Media will ensure that X encodes masters from the highest quality sources. |
| All times are GMT -6. The time now is 06:48 AM. |
