-   Final Cut Pro X (https://www.dvinfo.net/forum/final-cut-pro-x/)
-   -   Newbie "share" question (https://www.dvinfo.net/forum/final-cut-pro-x/531540-newbie-share-question.html)
William Hohauser April 10th, 2016 08:45 PM
Re: Newbie "share" question
How are you setting up the project? Are you letting FCPX decide from the first footage you place in the timeline or are you setting the project format specifics manually? If the first footage you place in the project is from the Canon and it's AVCHD then the project might not offer the XDCAM setting during export.
Alfred Okocha April 12th, 2016 07:11 AM
Thanks William. Not quite sure if that could be the problem or not. I'll do some tests.
Thanks.
