-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Using Color (https://www.dvinfo.net/forum/final-cut-suite/101003-using-color.html)
Nima Taheri August 9th, 2007 09:32 PM
Using Color
How do I get the footage on the timeline to Color in FCP6?
I tried to export XML, but when I go to 'send to - Color', the 'Color' choice is inactive...
Henrik Reach August 9th, 2007 11:59 PM
Does it work if you "Right-click->Send to->Motion" the sequence in the browser and try sending that way?
Nima Taheri August 10th, 2007 03:17 AM
I right-clicked the sequence, but 'Color' was still inactive. I also sent it to Motion, but couldn't figure out a way from there to send it to 'Color'?
Henrik Reach August 10th, 2007 03:26 AM
hehe I meant to right-click and send to Color, I guess I'm so used to sending stuff to Motion that I automatically wrote that instead..
Anyway, I can send all my sequences to Color, but not .motn-files or clips.
Nima Taheri August 10th, 2007 03:28 AM
Is there anything you have to do with the sequence before sending it to Color? I'm just testing this. I created a new sequence, and just dropped some footage on it, and rendered it. Is there anything else I have to do maybe?
Henrik Reach August 10th, 2007 03:35 AM
I don't have to do anything, all my sequences can be sent right away.
Color is working right, if so maybe there are some kind of settings that prevent it from being sent. I don't know if Color accepts everything or not. I've sent DV, HDV and DVCPro though, so it should take all normal stuff.
Nima Taheri August 10th, 2007 03:48 AM
I tried changing the settings from Uncompressed to different formats, but it's still not working. I also tried saving the sequence as xml, opened Color and imported it, but nothing came up...
