Failed Hardware:-(
Hi Everyone,
I have a 150 GB Maxtor hard drive that I've been working off of for several years now. It houses most of my music and sound effects library, as well as some photography and various FCP files. I had a power outage at my house not too long ago, and ever since then the drive has not been working. It spins and sounds fine, but when I plug it in to my computer it won't mount, and brings up the Disk Utility. The Disk Utility is able to see it, and when I try to Verify the disk it says that there is an "Invalid B-tree node" and that it needs to be repaired. When I hit repair, it won't complete and gives me a generic error. Does anyone know anything about repairing this drive? Or possibly rescuing/retrieving the files from it? The FCP files on there are not backed up (unfortunately) and are part of my demo reel update! Any help would be much appreciated! Thanks so much. |
I had the exact same problem with one of my Glyph drives. Since Glyph has a warranty for such issues, I sent it to them. They were able to recover all the data and fix the problem. They used a program called Disk Warrior. Drive has been fine since. Now I have a uninteruptable power supply.
I had a similar problem, only on the boot drive! The first thing I did was use the Unix command dd to make an exact copy of the disk, in case the problem was physical and I couldn't access the drive later. http://www.macosxhints.com/article.p...50302225659382 Then I used Disk Warrior and Drive Genius to recover the files from the disk image. I got a new hard drive and reinstalled the OS. Everything works fine now.
Continue repairing it. I once had to repair a disk 25 times to get it back to working order. B-Tree problems are problems in the directory of the disk (think of the last time you rearranged the card catalog at the local library). Fixing one problem often uncovers others.
Patience and persistence are the keys. I like to do this from the command line to get better feedback from the repair, if the node identifier changes (two numbers separated by a comma) within 3 attempts, keep trying...the command on the command line is: diskutil repairVolume '/Volumes/<volume name>' The single quotes will account for any spaces in the drive name...the double quotes should be omitted. |
Well speak of the devil.........
I just had a drive fail, and for the second time in my business I used software from http://www.runtime.org/ and recovered about 465 gig of files. You can download the demo, and bets are that if the software sees your files, you can get them back. The first drive I recovered, about 3 years ago, lost it's volume type, the one I did recently, just failed. So give that software a whirl. Let me know if it works. http://www.runtime.org/ customer service is good too, so you can email them if you have questions. |
No mac software that I could see there.
Thanks for all the info everyone! I tried everything I knew to do. I repeatedly tried to repair it in Disk Utility, and ran Disk Warrior on it multiple times. It always hung up and froze when it began trying to get data to rebuild.
I found out I'm leaving country on Wednesday to work on a documentary, and I caved. I took the drive to a data recovery girl a few friends have used. She's only recovered 1/4 of my data so far; the drive is pretty much toast. Does anyone have advice on the best drive type to use? I have about 2 terabites worth of data that I need to back up, and I need to replace the drive that failed. The girl working on my drive seems to think Seagate is the best. Maxtor and Lacie the worst, with Maxtor just generally being bad, and Lacie being near impossible to recover data from. Opinions? Suggestions? |
The advice everyone has given about trying to fix the drive over and over is the worst advice I've ever heard when it comes to data loss. Continually writing to a damaged/corrupt drive will most likely make the problem worse (which may explain the 1/4 recovery). The best thing you can do in this situation is install software on another drive, then attempt a recovery to another drive. Never try to fix the problem directly on the bad drive. I did a recovery for a guy who posted on Craig's List a few days ago. He had a RAID 0 (2 drives, striped) and I was able to recover all 49 gigs he needed from the drives. Trying to fix the drive resulted in further corruption of the filesystem but with the proper software, I was able to recover everything he needed. I burned it to DVD's, reformatted the RAID and reinstalled Windows x64 and it's running just fine again. This problem happened from a power failure while plugged into a surge protector. UPS's are definitely the way to go. I hope you're able to get back everything you need. :) Eric |
I've had tons of luck with maxtor and seagate, lots of failed WD drives. I used to admin ~900 servers with 512Gb each...plus about 10 Tb of RAIDs.
Yup, same here. I've had drives from every manufacturer crash on me over the years, somehow. But the Seagates have been the most reliable for me. IBM's drives (now built by Hitachi) I'd like to add to the list of drives to avoid. Especially their laptop drives, ugg.. But a quick search for 'hitachi deathstar' will show how many people have been unlucky with them (the real name is Deskstar).
Also, Maxtor is now owned by Seagate, so that should help improve whatever problems there may have been in the past. |
| All times are GMT -6. The time now is 01:27 PM. |
