-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Printing Still from a DVD (https://www.dvinfo.net/forum/final-cut-suite/103108-printing-still-dvd.html)
Chuck Spaulding September 8th, 2007 11:13 AM
Sorry this is a bit off topic.
A friend of mine recently purchase the sports car that William Holden drives in the movie Sabrina. It's a bit rough around the edges and wants to restore it to the same condition it was in the movie.
He'd like to get stills of the car from the movie but the DVD is copy protected.
Anyone know how I might be able to accomplish this?
Stu Holmes September 8th, 2007 12:20 PM
Play the DVD on a PC.
Pause it at the appropriate place.
Hit the "Prt Scrn" button towards top right of the PC keyboard.
This will take a screen-shot of the screen.
Paste it into any application : Word, Notepad, Wordpad, Excel, Photoshop etc , and crop it and then save or print as necessary.
EDIT: Sorry just see this is on Mac forum...
no problem, same sort of thing. Instead of "Prt Scrn", the mac equivalent is SHIFT + COMMAND + 3. You will hear a "click" (camera shutter) and the image is saved to the Images folder on the mac. Find it, import to IPhoto, and crop it and save it as necessary.
Chuck Spaulding September 8th, 2007 12:58 PM
Doesn't work. If the DVD is copy protected you can't use screen capture to grab a still and VLC won't play it.
I got a copy of MacRipper and that worked.
Thanks for the reply.
Jonathan Jones September 9th, 2007 12:41 PM
Chuck is correct. On the Mac, the screen grab functionality is disabled when the DVD player is active.
Probably your best bet in this situation would be SnapzProX from Ambrosia Software. I think there are a couple of versions available with corresponding pricing. I believe that the "stills only" capture version is about $29, and the higher priced one ($69) allows you to capture moving video.
I understand that there are a few other recently released competing products out there that are similar, some lower priced, and some higher, but I don't remember their names and haven't used them.
I use SnapzProX (video capture version) to capture onscreen video of my use of various applications to create demos of how to use those applications. Its pretty effortless.
-Jon
Chuck Spaulding September 10th, 2007 09:24 AM
Thanks for the info Jon.
I ended up using MacRipper with screen grab. The quality wasn't bad, but since I didn't care about quality [these are for reference] it was fine.
I'll check out SnapZPro. Thanks again.
Neil Rostance September 10th, 2007 12:36 PM
for a full rez version....
Use MPEG Stremclip to open the VOB file. Then export the frame as a still image.
