Open to suggestion in burning a hddvd in final cut
I do not have an hd burner so I can only burn on a d-5 4.7gigs or actualy a little less than that of hd material my problem is the hd material I want to burn is 7.6 gigs is there a way I can burn this material with my chapters and everything and take it to a dup house and have them put it on a hd dvd? Thanks in advance Gary Williams
Make a backup DVD....
The only suggestion (without sacrificing quality of your final product) would be to burn as an archive to DVDs (multiple DVDs) using Toast or another backup software package that will span multiple DVDs.
It is usually easier to just have an external drive kicking around so you can copy your source material onto it and then take it in to get burned. |
| All times are GMT -6. The time now is 07:36 PM. |
