Multiclip Problems, as Usual at DVinfo.net
Final Cut Suite
Old May 12th, 2008, 12:39 PM   #1
What is it with multiclip? I have to use it, and have used it for about a year. It's the most glichy application I've ever used. It doesn't matter if I wipe out preferences.
What happens, after I spend a half hour trying to get it to open and actually work on both the viewer and the canvas, is I will successfully cut a section. After hitting the space bar, I hit it again to do another secion. It marks the timeline as if it's working, but when I hit the space bar again, it reveals that it wasn't cutting anything, so somehow my keyboard shortcuts are toggling or SOMETHING!
Do I have to reinstall FCP?
www.LegacyHDV.com
Weddings | Corporate | HMC150s | FCPX | Encore | Lion
Dana Salsbury is offline   Reply With Quote
Old May 12th, 2008, 01:10 PM   #2
...I'm redoing it and limping along, hitting the spacebar after every 3-4 cuts. Still, I need to be able to put some weight on this thing!
www.LegacyHDV.com
Old May 16th, 2008, 02:34 PM   #3
I did a four camera concert shoot on Monday. This will be the first time I've used multiclips. I'm keeping my fingers crossed!
Joseph H. Moore is offline   Reply With Quote
Old May 16th, 2008, 03:23 PM   #4
I am not sure that that would help, Dana. Multiclip, as exciting and useful as the concept is, is just not very well implemented in the current version of Final Cut. Let's hope Apple takes a good look at it in a future release.
- Martin
Martin Pauly
Martin Pauly is offline   Reply With Quote
Old May 16th, 2008, 03:29 PM   #5
I have loved FCP for years and use for both work and personal use, but it wasn't until about a year or so ago that I had to use the multiclip function.
It is such a HORRIBLE attribute of the almighty FCP; it's embarrassingly bad, especially in comparison to what Premiere CS3 has that is comparable.
The problems get worse the longer you use it. Projects that I worked on 6 months ago--forget it. Clips lose links and then are all of a sudden hours different in timecode... its weird stuff going on. With live events and concert footage with 6 cameras, what other choice do you have?
I know people can easily say that if you use all the same cameras and even sync the timecode then it will take care of most of the problems... but that is not always feasible or practical and, seriously this glitchy area needs to be fixed.
I now use Premiere for all multi cam stuff. Ashamed to say it, but its true.
Ryan Postel is offline   Reply With Quote
Old May 16th, 2008, 10:42 PM   #6
Keyboard Commands
Dana,
It sounds like you are toggling and not cutting. Make sure you are presing Open-Apple and 1 (or whichever angle you want to choose) in order to make a cut. If you made a cut you did not like you would simply press the angle number without the open-apple key to toggle back to your previous clip without having to stop the timeline. Hope this helps.
For what it is worth, I love the multiclip part of FCP. I edit about 20-30 shows a month using it and have gotten to the point where I can pretty much do a straight through edit. I wish I could mix clips of different formats, but hopefully we will see that in an update soon.
Jonathan Schwartz
CA Video Productions
Jonathan Schwartz is offline   Reply With Quote
Old May 17th, 2008, 03:03 AM   #7
I'm not trying out my first play edited with Multiclip function, and although it was a pain to set everything synchronized (2 HDV cameras that had to switch tape during the event, 1 Sony EX1 for the wide shot, continuisly), it has done everything pretty smoothly until now.
I can imagine problems occuring if you shoot with 10 camera's instead of my 3, and a 4 hour long show instead of a 2 hour one, like me.
But the simplicity of the concept is so nice, and editing goes pretty fast.
So no problems for me thus far. I agree that maybe you are only switching angles, and not cutting them?
Good luck!
Mathieu Ghekiere is offline   Reply With Quote
Old May 17th, 2008, 06:41 AM   #8
I thought when you hit the space bar, all of your "toggles" became edits. Is that not correct?
Old May 17th, 2008, 06:59 AM   #9
Toggles vs Cuts
Joseph,
No. Unless you press the open apple key while pressing your angle number it will not make a cut. What you are doing is toggling between clips so whichever angle you pressed last before pressing the space bar will be the shot for the entire clip. Also make sure tha you have selected multicamera editing from Tools>Keyboard layout >multicamera editing.
Good luck
Jonathan Schwartz
Old May 17th, 2008, 09:29 AM   #10
But normally if you press the spacebar, and it runs, if you toggle with your mouse between the angles and click, it will make cuts.
(I'm doing this right now).
Old May 18th, 2008, 08:20 AM   #11
Johnathan, what do you mean by open apple key? Is that the command key?
David Tindale is offline   Reply With Quote
Old May 18th, 2008, 10:57 AM   #12
key
David,
Yes, Open apple same as command
Old May 18th, 2008, 11:06 AM   #13
FCP bug vs. user error
It sounds to me that the issue is more user error than it is FCP being buggy. As Jonathan Schwartz has already pointed out, it seems that people are toggling rather than actually cutting. Check your key commands.
Mike Barber
"I'm laughing to stop myself from screaming."
Mike Barber is offline   Reply With Quote
Old May 25th, 2008, 04:54 PM   #14
As Mathieu said "if you toggle with your mouse between the angles and click, it will make cuts."
I have used multiclip loads of times with no problem at all. There are many ways to select the scene you want and if it is 4 or less cameras I advise you use the mouse click way and leave the keyboard selection alone. Seems that might be your problem, not pressing the correct keys.
Dont blame the weather....improvise !
Andrew Paul is offline   Reply With Quote
Old May 25th, 2008, 05:39 PM   #15
I am in the process if editing a 3 camera shoot I did of a conference. So far I have rough-cut about 7 hours of footage using exclusively the multi-clip function. Yes, you do have to hold down the command key while selecting your angles, which I suppose would be more convenient not to have to, but you'll hear no complaints from me! I run an entire session and do my cuts in real-time like a switcher, and then if I need to fine-tune anything I can just roll the cuts.
I absolutely love editing this way and have had NO problems at all using it.
Frank Simpson is offline   Reply
