-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   FCP 6, Color, Sheer, HDV (https://www.dvinfo.net/forum/final-cut-suite/125373-fcp-6-color-sheer-hdv.html)
Amos Kim July 25th, 2008 12:58 AM
yea that's what apple has been professing for a while now about their prores, but I'm thinking with heavy grading, remastering, uprezzing to 1080p HDCAM for film fest exhibition, or transferring to film, the added compression of prores and it's lossy characteristic is gonna show in your originally compressed HDV footage. So, Paolo's logic is that if you have lofty ambitions for your footage, it's better to keep as much of the quality intact, because it may eventually show. Hence, Sheervideo codec or uncompressed. Even if you don't originally have grand plans for your HDV captured footage, who knows down the line if you'll need to remaster or do something fancy with the footage.
David Knaggs July 25th, 2008 01:21 AM
Originally Posted by Amos Kim (Post 911748)
... but I'm thinking with heavy grading, remastering, uprezzing to 1080p HDCAM for film fest exhibition, or transferring to film, the added compression of prores and it's lossy characteristic is gonna show in your originally compressed HDV footage. So, Paolo's logic is that if you have lofty ambitions for your footage, it's better to keep as much of the quality intact, ...
Yes, definitely. But the good thing is that it has clarified the question, "Is it better to go with Uncompressed 8-bit or Uncompressed 10-bit? Even though your source footage is only 8-bit."
Uncompressed 10-bit will give a better result (according to the logic outlined at the event).
