-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Matrox MXO and Firepod (https://www.dvinfo.net/forum/final-cut-suite/136469-matrox-mxo-firepod.html)
Paul Cronin October 22nd, 2008 04:03 PM
I hooked up a MXO to my Mac Pro to help with color on my second 24" Dell monitor. All of the video seems to be fine and I was able to calibrate the monitor with acceptable results.
The problem I have is when I view the video from the timeline using the second monitor with a Matrox setting I do not know how to get audio. I have my audio running on a firewire cable from the back of the tower to the Presonus Firepod that runs the two powered monitors.
Has anyone used the MXO with a Firepod?
I talked with Matrox yesterday and they said they would get right back to me but a day later nothing since they had no idea.
Noah Kadner October 22nd, 2008 06:46 PM
I'd be curious about that- I have a Firepod and it's a massive system hog. I wonder if it would be usable in that sort of configuration.
Noah
Paul Cronin October 23rd, 2008 07:05 AM
Noah not sure if it is the best path for audio out while using the MXO but I can't seem to find an answer from Matrox. I will try today to bypass the Firepod and see if that works.
I know a DVinfo user will come along and show me the right solution.
Paul Cronin October 23rd, 2008 09:12 AM
Noah the only way I can make audio work is with RCA in the back of MXO to the 1/4" back of powered monitors. The Firepod no longer has control of the powered monitors.
So for now I will disconnect the Firepod and monitor through the MXO in FC and use Firepod for all other audio. At lease the audio seem synced properly.
