Inerlacing issues with vimeo upload
Here is a short video i put togeather for whiteface mtn when i uploaded it to vimeo the interlacing went crazy. Any suggestions?
Whiteface Opening Weekend on Vimeo |
I edited and exported with FCP the footage was shot with a XH A1
You need to export a 'progressive' movie and re-upload to Vimeo. You could also try adding the 'deinterlace' filter on to each shot.
How do i export "Progressive" ? I looked around and cant seem to find anything.
If you are using Compressor, pick your codec (I use MPEG4), select Frame Controls, output fields: progressive and Deinterlace: Better (Motion Adaptive).
if i am not using compressor? The program wont open for some reason.
If you use Export: Using QT Conversion, there is a Deinterlace checkbox under Options: Video: Size. However, Compressor is useful and worth getting working.
N |
| All times are GMT -6. The time now is 07:34 PM. |
