-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Jagged edges - FCP/Compressor/Encore (https://www.dvinfo.net/forum/final-cut-suite/139773-jagged-edges-fcp-compressor-encore.html)
Shaun Roemich December 25th, 2008 07:38 AM
Originally Posted by Derek Nickell (Post 983688)
I cant remember what HDV is at.
Should be the same as DV as both are 25mbps ASSUMING you've captured the media as HDV and not as an intermediate codec.
Dana Salsbury December 25th, 2008 03:55 PM
I just don't see why I would render it twice. When things aren't working it sounds like a good step though.
Derek Nickell December 26th, 2008 10:32 PM
Thought so since it is recorded to MiniDV tape, just didnt want to give false info.
Derek Nickell December 26th, 2008 10:34 PM
It sounded like your stuff wasnt working. Did you try it? And you are only rendering once and transcoding once. Render the completed timeline to HDV when you export and transcode to MPEG-2 in compressor.
Dana Salsbury December 27th, 2008 09:38 AM
Thanks Derek. I got it to work the way you suggested and it saved the day. I still need to do some tests to try to get better quality. Now that all the deadlines are over I'll have some time to explore it.
Derek Nickell December 27th, 2008 04:26 PM
Not a problem. I try and stick my 2c in there when I can.
