What format for iMovie?
My daughter's teacher is asking me to capture a VHS tape so she can edit it and make a DVD. I have no clue about iMovie, and she has no clue about this whole thing...
Being a PC person, I can capture either into Premiere Pro or Edius. PremPro will give me a DV-AVI file in the dvsd codec, while Edius in the Canopus cdvc codec. I am pretty sure the Canopus codec will not play on a Mac, how about the standard Windows DV-AVI codec dvsd? Thanks, |
I doubt iMovie will like either of those codecs. Can you capture using DVCPRO?
QuickTime DV-NTSC should be available as an option on the PC if you install the QT Player. Also you'll need to format a drive as NTFS for them to ready it. Honestly I'd just loan them a deck or a camera so they can capture for themselves in iMovie. The added hassle of capturing and converting from a PC is huge here.
Noah |
iMovie have difficulties with .avi files. It can't open this format directly, but it can import .avi files. In the process however, which is painfully slow, a few megs turns into a gigantic file.
If you can't capture it as anything else, try running it through something like MPEG Streamclip into a .mov as a DV format Good Luck Ryan |
| All times are GMT -6. The time now is 07:07 PM. |
