-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Cleaner Goofiness (https://www.dvinfo.net/forum/final-cut-suite/18330-cleaner-goofiness.html)
Ted Springer December 14th, 2003 04:02 PM
Cleaner Goofiness
It seems I just can't win. Cleaner 6.0.1 seems to be broken. When I encode video, it messes it up, skewing it horribly. Check out this pic for an example. It ONLY does this in OS X. It works freakin' fantastic in OS 9 with the same settings (except that it uses KB instead of kb in OS X for some odd reason when tweaking Sorenson data rates).
Any idea what's going on here? Why is my Mac evil? Are all Macs evil?
EDIT: It only seems to do this with wide-aspect ratio Quicktimes, or when I change the aspect ratio in any way from the original. Again, this does not affect OS 9.
Ken Tanaka December 14th, 2003 08:34 PM
More info needed
What format is the original footage? 4:3? 16:9? I gather the latter but just to be sure.
Can you copy the text from the Summary tab (of your Cleaner Settings) here?
Ted Springer December 14th, 2003 09:52 PM
The original footage is usually flagged for 4:3 as it comes from a DVX100. If I crop letterbox footage I get the skewing... same if I stretch the footage in FCP to be an anamorphic DV file and then change the aspect ratio in Cleaner.
I can't copy and paste the text from Cleaner, but I can do the next best thing and post a screenshot of the summary
Ken Tanaka December 15th, 2003 12:08 AM
Nothing jumps out as being a problem. I am assuming, then, that you are exporting from FCP 4 (as Quicktime DV or as FCP file?) and that you are sending Cleaner 30fps 4:3 footage which you then crop to 430x240? What aspect ratio in Cleaner do you select under the crop? (ex: Same as source, same as cropped, etc.)
I wonder if some of your troubles in this thread could be related to this.
Sharon Fraats December 15th, 2003 12:13 AM
Could you not export from QuickTime Pro as a QT movie yet use MPEG4 to compress it or to stream it?
Question is what do you want your final source to be?
Jeff Donald December 15th, 2003 07:16 AM
On the Apple FCP discussion pages there are comments relating to Cleaner not working well with compressor. I can't test any of this for you Ted, as I'm still on FCP 3.
Ted Springer December 15th, 2003 08:15 AM
The footage is 24fps progressive, and I want it to be Sorenson 3 24fps. I use unconstrained for the cropping and aspect ratio, because I know exactly what size the video needs to be (plus I like the control).
Works great in OS 9.
I'm amazed that you're still on FCP3, Jeff. You seem to know quite a bit about version 4. Though wouldn't someone use Cleaner or Compressor?
John Locke December 15th, 2003 10:32 AM
Ted,
You're right...it would be either/or.
I got a similar look recently when I accidentally tried to compress a PAL sequence made in FCP as NTSC in Cleaner.
Have you double-checked your FCP settings? Both the sequence settings and the export settings?
Here's what should be the sure fire way of getting a result:
1. Export as "Quicktime Movie" then select "uncompressed 10-bit NTSC"
2. Import that into Cleaner and choose one of the Quicktime NTSC presets, being sure to set the ratio for wide screen.
Sharon Fraats December 15th, 2003 12:31 PM
Did you do a 2:3:3:2 pull down removal upon import and then export in QT with the same settings or converted back?
Ted Springer December 15th, 2003 03:25 PM
I don't need to do a pulldown since the source file and the Quicktime will be 24 progressive. I am at work right now so I will try the uncompressed option a little later and let you know my results.
Jeff Donald December 15th, 2003 04:07 PM
I have access to a computer with FCP 4 at school, but we're not teaching it yet. We'll probably switch in the summer or next fall. I will purchase FCP 4 for myself when I upgrade to a G5 in the next month or so.
Ted Springer December 15th, 2003 08:59 PM
Exporting as an uncompressed movie worked! I guess Cleaner can be a bit finicky with DV files.
Thanks to everyone!
